{"name":"\u0424\u043e\u0440\u0443\u043c \u0441\u043e\u043e\u0431\u0449\u0435\u0441\u0442\u0432\u0430 BIM2B","description":"","url":"https:\/\/forum.bim2b.ru","home":"https:\/\/forum.bim2b.ru","gmt_offset":"3","timezone_string":"","page_for_posts":0,"page_on_front":2,"show_on_front":"page","namespaces":["oembed\/1.0","wordfence\/v1","google-site-kit\/v1","buddypress\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":[],"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL \u0440\u0435\u0441\u0443\u0440\u0441\u0430 \u0434\u043b\u044f \u043f\u043e\u043b\u0443\u0447\u0435\u043d\u0438\u044f oEmbed \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL \u0440\u0435\u0441\u0443\u0440\u0441\u0430 \u0434\u043b\u044f \u043f\u043e\u043b\u0443\u0447\u0435\u043d\u0438\u044f oEmbed \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","format":"uri","required":true},"format":{"description":"\u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0444\u043e\u0440\u043c\u0430\u0442 oEmbed.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u0430\u044f \u0448\u0438\u0440\u0438\u043d\u0430 \u0432\u043d\u0435\u0434\u0440\u044f\u0435\u043c\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u0432 \u043f\u0438\u043a\u0441\u0435\u043b\u044f\u0445. ","type":"integer","default":600,"required":false},"maxheight":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u0430\u044f \u0432\u044b\u0441\u043e\u0442\u0430 \u0432\u043d\u0435\u0434\u0440\u044f\u0435\u043c\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u0432 \u043f\u0438\u043a\u0441\u0435\u043b\u044f\u0445.","type":"integer","required":false},"discover":{"description":"\u041f\u0440\u043e\u0438\u0437\u0432\u043e\u0434\u0438\u0442\u044c \u043b\u0438 \u043f\u043e\u0438\u0441\u043a\u043e\u0432\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 oEmbed \u0434\u043b\u044f \u043f\u0440\u043e\u0432\u0430\u0439\u0434\u0435\u0440\u043e\u0432 \u043d\u0435 \u0438\u0437 \u0431\u0435\u043b\u043e\u0433\u043e \u0441\u043f\u0438\u0441\u043a\u0430.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wordfence\/v1":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wordfence\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1"}]}},"\/wordfence\/v1\/authenticate":{"namespace":"wordfence\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/authenticate"}]}},"\/wordfence\/v1\/authenticate-premium":{"namespace":"wordfence\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/authenticate-premium"}]}},"\/wordfence\/v1\/config":{"namespace":"wordfence\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/config"}]}},"\/wordfence\/v1\/disconnect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/disconnect"}]}},"\/wordfence\/v1\/premium-connect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/premium-connect"}]}},"\/wordfence\/v1\/scan\/issues":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/scan\/issues"}]}},"\/wordfence\/v1\/scan":{"namespace":"wordfence\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/scan"}]}},"\/wordfence\/v1\/scan\/issue":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wordfence\/v1\/scan\/issue"}]}},"\/oembed\/1.0\/embed\/activity":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"hide_media":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/oembed\/1.0\/embed\/activity"}]}},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false},"data":{"type":"object","description":"\u041d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438 \u0434\u043b\u044f \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043a\u0438.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false},"datapoint":{"type":"string","description":"\u0410\u0434\u0440\u0435\u0441 \u0434\u0430\u043d\u043d\u044b\u0445 \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false},"datapoint":{"type":"string","description":"\u0410\u0434\u0440\u0435\u0441 \u0434\u0430\u043d\u043d\u044b\u0445 \u043c\u043e\u0434\u0443\u043b\u044f.","default":null,"required":false},"data":{"type":"object","description":"\u0414\u0430\u043d\u043d\u044b\u0435 \u0434\u043b\u044f \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043a\u0438.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/buddypress\/v1":{"namespace":"buddypress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"buddypress\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1"}]}},"\/buddypress\/v1\/components":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"status":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0441\u0442\u0430\u0442\u0443\u0441\u043e\u043c.","default":"all","type":"string","enum":["all","active","inactive"],"required":false},"type":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u0442\u0438\u043f\u0430.","default":"all","type":"string","enum":["all","optional","retired","required"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"type":"string","description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442\u0430.","required":true},"action":{"description":"\u0410\u043a\u0442\u0438\u0432\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0438\u043b\u0438 \u0434\u0435\u0430\u043a\u0442\u0438\u0432\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442.","type":"string","enum":["activate","deactivate"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/components"}]}},"\/buddypress\/v1\/members":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"type":{"description":"\u0421\u043e\u043a\u0440\u0430\u0449\u0435\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u043a\u043e\u043c\u0431\u0438\u043d\u0430\u0446\u0438\u0439 \u0437\u0430\u043a\u0430\u0437\u0430\/\u0437\u0430\u043a\u0430\u0437\u0430.","default":"newest","type":"string","enum":["active","newest","alphabetical","random","online","popular"],"required":false},"user_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0442\u043e\u043b\u044c\u043a\u043e \u0434\u0440\u0443\u0437\u044c\u044f\u043c\u0438 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","default":0,"type":"integer","required":false},"user_ids":{"description":"\u041f\u0435\u0440\u0435\u0434\u0430\u0439\u0442\u0435 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439, \u0447\u0442\u043e\u0431\u044b \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432.","default":[],"type":"array","items":{"type":"integer"},"required":false},"include":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0432\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b.","default":[],"type":"array","items":{"type":"integer"},"required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","default":[],"type":"array","items":{"type":"integer"},"required":false},"populate_extras":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0434\u043e\u043f\u043e\u043b\u043d\u0438\u0442\u0435\u043b\u044c\u043d\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 BP \u043e \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043d\u044b\u0445 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430\u0445.","default":false,"type":"boolean","required":false},"member_type":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0442\u0438\u043f\u0430\u043c\u0438.","default":[],"type":"array","items":{"type":"string"},"required":false},"xprofile":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u043d\u0430\u0431\u043e\u0440\u043e\u043c \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u043f\u043e\u043b\u0435\u0439 XProfile.","type":["array","object"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"string","required":false},"user_login":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"string","required":true},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430 (\u043d\u0438\u043a\u043e\u0433\u0434\u0430 \u043d\u0435 \u0432\u043a\u043b\u044e\u0447\u0435\u043d).","type":"string","required":true},"roles":{"description":"\u0420\u043e\u043b\u0438, \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0443.","type":"array","items":{"type":"string"},"required":false},"member_type":{"description":"\u041d\u0430\u0437\u043d\u0430\u0447\u044c\u0442\u0435 \u0442\u0438\u043f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0447\u043b\u0435\u043d\u0443. \u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u0441\u043f\u0438\u0441\u043e\u043a \u0442\u0438\u043f\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438, \u0447\u0442\u043e\u0431\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0431\u043e\u043b\u0435\u0435 \u043e\u0434\u043d\u043e\u0433\u043e.","type":"string","enum":[],"required":false},"email":{"description":"\u0410\u0434\u0440\u0435\u0441 \u044d\u043b\u0435\u043a\u0442\u0440\u043e\u043d\u043d\u043e\u0439 \u043f\u043e\u0447\u0442\u044b \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"string","format":"email","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/members"}]}},"\/buddypress\/v1\/members\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"populate_extras":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0434\u043e\u043f\u043e\u043b\u043d\u0438\u0442\u0435\u043b\u044c\u043d\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 BP \u043e \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043d\u043e\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0435.","default":false,"type":"boolean","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"integer","required":false},"name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"string","required":false},"roles":{"description":"\u0420\u043e\u043b\u0438, \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0443.","type":"array","items":{"type":"string"},"required":false},"member_type":{"description":"\u041d\u0430\u0437\u043d\u0430\u0447\u044c\u0442\u0435 \u0442\u0438\u043f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0447\u043b\u0435\u043d\u0443. \u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u0441\u043f\u0438\u0441\u043e\u043a \u0442\u0438\u043f\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438, \u0447\u0442\u043e\u0431\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0431\u043e\u043b\u0435\u0435 \u043e\u0434\u043d\u043e\u0433\u043e.","type":"string","enum":[],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u043f\u0440\u0430\u0432\u0434\u043e\u0439, \u043f\u043e\u0441\u043a\u043e\u043b\u044c\u043a\u0443 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0438 \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u0432\u044b\u0431\u0440\u0430\u0441\u044b\u0432\u0430\u043d\u0438\u0435 \u043c\u0443\u0441\u043e\u0440\u0430.","required":false},"reassign":{"type":"integer","description":"\u041f\u0435\u0440\u0435\u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u0438 \u0441\u0441\u044b\u043b\u043a\u0438 \u0443\u0434\u0430\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430 \u044d\u0442\u043e\u043c\u0443 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u0443 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","required":true}}}]},"\/buddypress\/v1\/members\/me":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"string","required":false},"roles":{"description":"\u0420\u043e\u043b\u0438, \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0443.","type":"array","items":{"type":"string"},"required":false},"member_type":{"description":"\u041d\u0430\u0437\u043d\u0430\u0447\u044c\u0442\u0435 \u0442\u0438\u043f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0447\u043b\u0435\u043d\u0443. \u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u0441\u043f\u0438\u0441\u043e\u043a \u0442\u0438\u043f\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438, \u0447\u0442\u043e\u0431\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0431\u043e\u043b\u0435\u0435 \u043e\u0434\u043d\u043e\u0433\u043e.","type":"string","enum":[],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u044b\u043c, \u0442\u0430\u043a \u043a\u0430\u043a \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439 \u043d\u0435\u043b\u044c\u0437\u044f \u043f\u0435\u0440\u0435\u043c\u0435\u0441\u0442\u0438\u0442\u044c \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443.","required":false},"reassign":{"type":"integer","description":"\u041f\u0435\u0440\u0435\u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0443\u0434\u0430\u043b\u0435\u043d\u043d\u044b\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f \u0438 \u0441\u0441\u044b\u043b\u043a\u0438 \u043d\u0430 \u044d\u0442\u043e\u0442 ID \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/members\/me"}]}},"\/buddypress\/v1\/members\/(?P<user_id>[\\d]+)\/avatar":{"namespace":"buddypress\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"html":{"description":"\u0412\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0442\u044c \u043b\u0438 HTML-\u044d\u043b\u0435\u043c\u0435\u043d\u0442 <img> \u0438\u043b\u0438 \u043d\u0435\u043e\u0431\u0440\u0430\u0431\u043e\u0442\u0430\u043d\u043d\u044b\u0439 URL-\u0430\u0434\u0440\u0435\u0441 \u0430\u0432\u0430\u0442\u0430\u0440\u0430.","default":false,"type":"boolean","required":false},"alt":{"description":"\u0410\u0442\u0440\u0438\u0431\u0443\u0442 alt \u0434\u043b\u044f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 <img>.","default":"","type":"string","required":false},"no_gravatar":{"description":"\u041e\u0442\u043a\u043b\u044e\u0447\u0438\u0442\u044c \u043b\u0438 \u0440\u0435\u0437\u0435\u0440\u0432\u043d\u044b\u0439 \u0432\u0430\u0440\u0438\u0430\u043d\u0442 Gravatar \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e.","default":false,"type":"boolean","required":false}}},{"methods":["POST"],"args":{"user_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"user_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430.","type":"integer","required":false}}}]},"\/buddypress\/v1\/members\/(?P<user_id>[\\d]+)\/cover":{"namespace":"buddypress\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 ID \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":false}}},{"methods":["POST"],"args":{"user_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 ID \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"user_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 ID \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":false}}}]},"\/buddypress\/v1\/xprofile\/fields":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"profile_group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u0435\u0441\u0442\u044c \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":0,"type":"integer","required":false},"hide_empty_groups":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0443 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u043d\u0435\u0442 \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0438\u043b\u0438 \u043d\u0435\u0442.","default":false,"type":"boolean","required":false},"user_id":{"description":"\u041d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e, \u0435\u0441\u043b\u0438 \u0432\u044b \u0445\u043e\u0442\u0438\u0442\u0435 \u0437\u0430\u0433\u0440\u0443\u0437\u0438\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0435 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u043e\u0433\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","default":0,"type":"integer","required":false},"member_type":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u044c\u0442\u0435 \u043f\u043e\u043b\u044f \u0442\u0435\u043c\u0438, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u044b \u0434\u0430\u043d\u043d\u044b\u043c \u0442\u0438\u043f\u043e\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0438\u043b\u0438 \u043c\u0430\u0441\u0441\u0438\u0432\u043e\u043c \u0442\u0438\u043f\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432. \u0415\u0441\u043b\u0438 \u0443\u043a\u0430\u0437\u0430\u043d `$user_id`, \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435 `$member_type` \u0431\u0443\u0434\u0435\u0442 \u043f\u0435\u0440\u0435\u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043e \u0442\u0438\u043f\u0430\u043c\u0438 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f. \u0421\u043f\u0435\u0446\u0438\u0430\u043b\u044c\u043d\u043e\u0435 \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435 'any' \u0432\u0435\u0440\u043d\u0435\u0442 \u0442\u043e\u043b\u044c\u043a\u043e \u0442\u0435 \u043f\u043e\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u043d\u0435 \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u044b \u0442\u0438\u043f\u043e\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430, \u0442.\u0435. \u0442\u0435, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u043f\u0440\u0438\u043c\u0435\u043d\u0438\u043c\u044b \u043a \u043b\u044e\u0431\u043e\u043c\u0443 \u0442\u0438\u043f\u0443.","default":[],"type":"array","items":{"type":"string"},"required":false},"hide_empty_fields":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0433\u0434\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c \u043d\u0435 \u043f\u0440\u0435\u0434\u043e\u0441\u0442\u0430\u0432\u0438\u043b \u0434\u0430\u043d\u043d\u044b\u0435, \u0438\u043b\u0438 \u043d\u0435\u0442.","default":false,"type":"boolean","required":false},"fetch_field_data":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0435 \u0434\u043b\u044f \u043a\u0430\u0436\u0434\u043e\u0433\u043e \u043f\u043e\u043b\u044f. \u0422\u0440\u0435\u0431\u0443\u0435\u0442\u0441\u044f $user_id.","default":false,"type":"boolean","required":false},"signup_fields_only":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0442\u044c \u0442\u043e\u043b\u044c\u043a\u043e \u043f\u043e\u043b\u044f \u0434\u043b\u044f \u0440\u0435\u0433\u0438\u0441\u0442\u0440\u0430\u0446\u0438\u0438.","default":false,"type":"boolean","required":false},"fetch_visibility_level":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0443\u0440\u043e\u0432\u0435\u043d\u044c \u0432\u0438\u0434\u0438\u043c\u043e\u0441\u0442\u0438 \u0434\u043b\u044f \u043a\u0430\u0436\u0434\u043e\u0433\u043e \u043f\u043e\u043b\u044f.","default":false,"type":"boolean","required":false},"include_groups":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0438\u0440\u0443\u044e\u0449\u0438\u0439 \u043d\u0430\u0431\u043e\u0440 \u0432\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":[],"type":"array","items":{"type":"integer"},"required":false},"exclude_groups":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":[],"type":"array","items":{"type":"integer"},"required":false},"exclude_fields":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":[],"type":"array","items":{"type":"string"},"required":false},"update_meta_cache":{"description":"\u0421\u043b\u0435\u0434\u0443\u0435\u0442 \u043b\u0438 \u043f\u0440\u0435\u0434\u0432\u0430\u0440\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u043f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u043c\u0435\u0442\u0430-\u0444\u0430\u0439\u043b xprofile \u0434\u043b\u044f \u0432\u0441\u0435\u0445 \u0438\u0437\u0432\u043b\u0435\u0447\u0435\u043d\u043d\u044b\u0445 \u0433\u0440\u0443\u043f\u043f, \u043f\u043e\u043b\u0435\u0439 \u0438 \u0434\u0430\u043d\u043d\u044b\u0445.","default":true,"type":"boolean","required":false}}},{"methods":["POST"],"args":{"group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b, \u0447\u0430\u0441\u0442\u044c\u044e \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u043f\u043e\u043b\u0435.","type":"integer","required":true},"parent_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0433\u043e \u043f\u043e\u043b\u044f.","type":"integer","required":false},"type":{"description":"\u0422\u0438\u043f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","enum":["checkbox","datebox","multiselectbox","number","url","radio","selectbox","textarea","textbox","telephone","wp-biography","wp-textbox","checkbox_acceptance","option"],"required":true},"name":{"description":"\u0418\u043c\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","required":true},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","default":"","required":false},"is_required":{"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0435 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0438\u043c\u0435\u0442\u044c \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435.","type":"boolean","required":false},"can_delete":{"default":true,"description":"\u041c\u043e\u0436\u043d\u043e \u043b\u0438 \u0443\u0434\u0430\u043b\u0438\u0442\u044c \u043f\u043e\u043b\u0435 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"boolean","required":false},"field_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0432 \u0433\u0440\u0443\u043f\u043f\u0435 \u043f\u043e\u043b\u0435\u0439.","type":"integer","required":false},"option_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u043e\u043f\u0446\u0438\u0439 \u0432 \u0441\u043f\u0438\u0441\u043a\u0435 \u043e\u043f\u0446\u0438\u0439 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false},"order_by":{"default":"asc","description":"\u0421\u043f\u043e\u0441\u043e\u0431 \u0443\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0435\u043d\u0438\u044f \u043e\u043f\u0446\u0438\u0439 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","enum":["asc","desc"],"required":false},"is_default_option":{"description":"\u042f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u043b\u0438 \u044d\u0442\u043e\u0442 \u043f\u0430\u0440\u0430\u043c\u0435\u0442\u0440 \u043f\u0430\u0440\u0430\u043c\u0435\u0442\u0440\u043e\u043c \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e \u0434\u043b\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"boolean","required":false},"default_visibility":{"default":"public","description":"\u0412\u0438\u0434\u0438\u043c\u043e\u0441\u0442\u044c \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e \u0434\u043b\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","enum":["public","adminsonly","loggedin","friends"],"required":false},"allow_custom_visibility":{"description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0438\u0442\u044c \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430\u043c \u0443\u0441\u0442\u0430\u043d\u0430\u0432\u043b\u0438\u0432\u0430\u0442\u044c \u0432\u0438\u0434\u0438\u043c\u043e\u0441\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0445 \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0438\u043b\u0438 \u043d\u0435\u0442.","default":"allowed","type":"string","enum":["allowed","disabled"],"required":false},"do_autolink":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0430\u0432\u0442\u043e\u0441\u0441\u044b\u043b\u043a\u0438 \u0434\u043b\u044f \u044d\u0442\u043e\u0433\u043e \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":"off","type":"string","enum":["on","off"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/xprofile\/fields"}]}},"\/buddypress\/v1\/xprofile\/fields\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false},"user_id":{"description":"\u041d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e, \u0435\u0441\u043b\u0438 \u0432\u044b \u0445\u043e\u0442\u0438\u0442\u0435 \u0437\u0430\u0433\u0440\u0443\u0437\u0438\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0435 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u043e\u0433\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","default":0,"type":"integer","required":false},"fetch_field_data":{"description":"\u0421\u043b\u0435\u0434\u0443\u0435\u0442 \u043b\u0438 \u0438\u0437\u0432\u043b\u0435\u043a\u0430\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0435 \u0434\u043b\u044f \u043f\u043e\u043b\u044f. \u0422\u0440\u0435\u0431\u0443\u0435\u0442\u0441\u044f $user_id.","default":false,"type":"boolean","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false},"group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b, \u0447\u0430\u0441\u0442\u044c\u044e \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u043f\u043e\u043b\u0435.","type":"integer","required":false},"parent_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0433\u043e \u043f\u043e\u043b\u044f.","type":"integer","required":false},"type":{"description":"\u0422\u0438\u043f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","enum":["checkbox","datebox","multiselectbox","number","url","radio","selectbox","textarea","textbox","telephone","wp-biography","wp-textbox","checkbox_acceptance","option"],"required":false},"name":{"description":"\u0418\u043c\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","default":"","required":false},"is_required":{"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0435 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0438\u043c\u0435\u0442\u044c \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435.","type":"boolean","required":false},"can_delete":{"description":"\u041c\u043e\u0436\u043d\u043e \u043b\u0438 \u0443\u0434\u0430\u043b\u0438\u0442\u044c \u043f\u043e\u043b\u0435 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"boolean","default":true,"required":false},"field_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0432 \u0433\u0440\u0443\u043f\u043f\u0435 \u043f\u043e\u043b\u0435\u0439.","type":"integer","required":false},"option_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u043e\u043f\u0446\u0438\u0439 \u0432 \u0441\u043f\u0438\u0441\u043a\u0435 \u043e\u043f\u0446\u0438\u0439 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false},"order_by":{"description":"\u0421\u043f\u043e\u0441\u043e\u0431 \u0443\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0435\u043d\u0438\u044f \u043e\u043f\u0446\u0438\u0439 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","enum":["asc","desc"],"default":"asc","required":false},"is_default_option":{"description":"\u042f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u043b\u0438 \u044d\u0442\u043e\u0442 \u043f\u0430\u0440\u0430\u043c\u0435\u0442\u0440 \u043f\u0430\u0440\u0430\u043c\u0435\u0442\u0440\u043e\u043c \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e \u0434\u043b\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"boolean","required":false},"default_visibility":{"description":"\u0412\u0438\u0434\u0438\u043c\u043e\u0441\u0442\u044c \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e \u0434\u043b\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","enum":["public","adminsonly","loggedin","friends"],"default":"public","required":false},"allow_custom_visibility":{"description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0438\u0442\u044c \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430\u043c \u0443\u0441\u0442\u0430\u043d\u0430\u0432\u043b\u0438\u0432\u0430\u0442\u044c \u0432\u0438\u0434\u0438\u043c\u043e\u0441\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0445 \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f \u0438\u043b\u0438 \u043d\u0435\u0442.","default":"allowed","type":"string","enum":["allowed","disabled"],"required":false},"do_autolink":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0430\u0432\u0442\u043e\u0441\u0441\u044b\u043b\u043a\u0438 \u0434\u043b\u044f \u044d\u0442\u043e\u0433\u043e \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":"off","type":"string","enum":["on","off"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false},"delete_data":{"description":"\u041e\u0431\u044f\u0437\u0430\u0442\u0435\u043b\u044c\u043d\u043e, \u0435\u0441\u043b\u0438 \u0432\u044b \u0445\u043e\u0442\u0438\u0442\u0435 \u0443\u0434\u0430\u043b\u0438\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439 \u0434\u043b\u044f \u043f\u043e\u043b\u044f.","default":false,"type":"boolean","required":false}}}]},"\/buddypress\/v1\/xprofile\/groups":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"profile_group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u0435\u0441\u0442\u044c \u043f\u043e\u043b\u044f.","default":0,"type":"integer","required":false},"hide_empty_groups":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0443 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u043d\u0435\u0442 \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0438\u043b\u0438 \u043d\u0435\u0442.","default":false,"type":"boolean","required":false},"user_id":{"description":"\u041d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e, \u0435\u0441\u043b\u0438 \u0432\u044b \u0445\u043e\u0442\u0438\u0442\u0435 \u0437\u0430\u0433\u0440\u0443\u0437\u0438\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0435 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u043e\u0433\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","default":0,"type":"integer","required":false},"member_type":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u044c\u0442\u0435 \u043f\u043e\u043b\u044f \u0442\u0435\u043c\u0438, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u044b \u0434\u0430\u043d\u043d\u044b\u043c \u0442\u0438\u043f\u043e\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0438\u043b\u0438 \u043c\u0430\u0441\u0441\u0438\u0432\u043e\u043c \u0442\u0438\u043f\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432. \u0415\u0441\u043b\u0438 \u0443\u043a\u0430\u0437\u0430\u043d `$user_id`, \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435 `$member_type` \u0431\u0443\u0434\u0435\u0442 \u043f\u0435\u0440\u0435\u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043e \u0442\u0438\u043f\u0430\u043c\u0438 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f. \u0421\u043f\u0435\u0446\u0438\u0430\u043b\u044c\u043d\u043e\u0435 \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435 'any' \u0432\u0435\u0440\u043d\u0435\u0442 \u0442\u043e\u043b\u044c\u043a\u043e \u0442\u0435 \u043f\u043e\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u043d\u0435 \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u044b \u0442\u0438\u043f\u043e\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430, \u0442.\u0435. \u0442\u0435, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u043f\u0440\u0438\u043c\u0435\u043d\u0438\u043c\u044b \u043a \u043b\u044e\u0431\u043e\u043c\u0443 \u0442\u0438\u043f\u0443.","default":[],"type":"array","items":{"type":"string"},"required":false},"hide_empty_fields":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0443 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u043d\u0435\u0442 \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f, \u0438\u043b\u0438 \u043d\u0435\u0442.","default":false,"type":"boolean","required":false},"fetch_fields":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u043f\u043e\u043b\u044f \u0434\u043b\u044f \u043a\u0430\u0436\u0434\u043e\u0439 \u0433\u0440\u0443\u043f\u043f\u044b.","default":false,"type":"boolean","required":false},"signup_fields_only":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0442\u044c \u0442\u043e\u043b\u044c\u043a\u043e \u043f\u043e\u043b\u044f \u0434\u043b\u044f \u0440\u0435\u0433\u0438\u0441\u0442\u0440\u0430\u0446\u0438\u0438.","default":false,"type":"boolean","required":false},"fetch_field_data":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0434\u0430\u043d\u043d\u044b\u0435 \u0434\u043b\u044f \u043a\u0430\u0436\u0434\u043e\u0433\u043e \u043f\u043e\u043b\u044f. \u0422\u0440\u0435\u0431\u0443\u0435\u0442\u0441\u044f $user_id.","default":false,"type":"boolean","required":false},"fetch_visibility_level":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0443\u0440\u043e\u0432\u0435\u043d\u044c \u0432\u0438\u0434\u0438\u043c\u043e\u0441\u0442\u0438 \u0434\u043b\u044f \u043a\u0430\u0436\u0434\u043e\u0433\u043e \u043f\u043e\u043b\u044f.","default":false,"type":"boolean","required":false},"include_groups":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0438\u0440\u0443\u044e\u0449\u0438\u0439 \u043d\u0430\u0431\u043e\u0440 \u0432\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":[],"type":"array","items":{"type":"integer"},"required":false},"exclude_groups":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":[],"type":"array","items":{"type":"integer"},"required":false},"exclude_fields":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044f \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","default":[],"type":"array","items":{"type":"string"},"required":false},"update_meta_cache":{"description":"\u0421\u043b\u0435\u0434\u0443\u0435\u0442 \u043b\u0438 \u043f\u0440\u0435\u0434\u0432\u0430\u0440\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u043f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u043c\u0435\u0442\u0430-\u0444\u0430\u0439\u043b xprofile \u0434\u043b\u044f \u0432\u0441\u0435\u0445 \u0438\u0437\u0432\u043b\u0435\u0447\u0435\u043d\u043d\u044b\u0445 \u0433\u0440\u0443\u043f\u043f, \u043f\u043e\u043b\u0435\u0439 \u0438 \u0434\u0430\u043d\u043d\u044b\u0445.","default":true,"type":"boolean","required":false}}},{"methods":["POST"],"args":{"name":{"description":"\u0418\u043c\u044f \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/xprofile\/groups"}]}},"\/buddypress\/v1\/xprofile\/groups\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false},"name":{"description":"\u0418\u043c\u044f \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"string","required":false},"group_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e\u043b\u0435\u0439 \u043f\u0440\u043e\u0444\u0438\u043b\u044f.","type":"integer","required":false}}}]},"\/buddypress\/v1\/xprofile\/(?P<field_id>[\\d]+)\/data\/(?P<user_id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"field_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044f, \u0438\u0437 \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u0432\u0437\u044f\u0442\u044b \u0434\u0430\u043d\u043d\u044b\u0435.","type":"integer","required":true},"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043e\u0442 \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043f\u043e\u043b\u0443\u0447\u0435\u043d\u044b \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044f.","type":"integer","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"field_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044f, \u0438\u0437 \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u0432\u0437\u044f\u0442\u044b \u0434\u0430\u043d\u043d\u044b\u0435.","type":"integer","required":true},"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043e\u0442 \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043f\u043e\u043b\u0443\u0447\u0435\u043d\u044b \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044f.","type":"integer","required":true},"value":{"description":"\u0417\u043d\u0430\u0447\u0435\u043d\u0438\u0435(\u044f) (\u0441\u043f\u0438\u0441\u043e\u043a \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0439, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438, \u043d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u044c \u0432 \u0441\u043b\u0443\u0447\u0430\u0435 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u0445 \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0439) \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u044b\u0445 \u043f\u043e\u043b\u044f.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"field_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044f, \u0438\u0437 \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u0432\u0437\u044f\u0442\u044b \u0434\u0430\u043d\u043d\u044b\u0435.","type":"integer","required":true},"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043e\u0442 \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043f\u043e\u043b\u0443\u0447\u0435\u043d\u044b \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044f.","type":"integer","required":true}}}]},"\/buddypress\/v1\/activity":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","default":[],"type":"array","items":{"type":"integer"},"required":false},"include":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0432\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b.","default":[],"type":"array","items":{"type":"integer"},"required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","default":"desc","type":"string","enum":["asc","desc"],"required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438, \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u043e\u0439 \u0434\u0430\u0442\u044b, \u0441\u043e\u043e\u0442\u0432\u0435\u0442\u0441\u0442\u0432\u0443\u044e\u0449\u0435\u0439 \u0441\u0442\u0430\u043d\u0434\u0430\u0440\u0442\u0443 ISO8601.","type":"string","format":"date-time","required":false},"user_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438, \u0441\u043e\u0437\u0434\u0430\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u043c (ID).","default":0,"type":"integer","required":false},"status":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0441\u0442\u0430\u0442\u0443\u0441\u043e\u043c.","default":"ham_only","type":"string","enum":["ham_only","spam_only","all"],"required":false},"scope":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u044c\u0442\u0435 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0438\u0440\u0443\u044e\u0449\u0438\u0439 \u043d\u0430\u0431\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0439 \u043e\u0431\u043b\u0430\u0441\u0442\u044c\u044e \u043f\u0440\u0438\u043c\u0435\u043d\u0435\u043d\u0438\u044f.","type":"string","enum":["just-me","friends","groups","favorites","mentions"],"required":false},"group_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438, \u0441\u043e\u0437\u0434\u0430\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0439 \u0433\u0440\u0443\u043f\u043f\u043e\u0439.","default":0,"type":"integer","required":false},"site_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438, \u0441\u043e\u0437\u0434\u0430\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0441\u0430\u0439\u0442\u043e\u043c.","default":0,"type":"integer","required":false},"primary_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u043e\u043c \u043e\u0441\u043d\u043e\u0432\u043d\u043e\u0439 \u0430\u0441\u0441\u043e\u0446\u0438\u0430\u0446\u0438\u0438.","default":0,"type":"integer","required":false},"secondary_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u043e\u043c \u0432\u0442\u043e\u0440\u0438\u0447\u043d\u043e\u0439 \u0430\u0441\u0441\u043e\u0446\u0438\u0430\u0446\u0438\u0438.","default":0,"type":"integer","required":false},"component":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0430\u043a\u0442\u0438\u0432\u043d\u044b\u043c \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442\u043e\u043c BuddyPress.","type":"string","enum":["xprofile","settings","friends","messages","activity","notifications","groups","blogs","members","members_invitations","community"],"required":false},"type":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u044c\u0442\u0435 \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0442\u0438\u043f\u043e\u043c \u0430\u043a\u0442\u0438\u0432\u043d\u043e\u0441\u0442\u0438.","type":"array","items":{"enum":["new_member","new_avatar","updated_profile","activity_update","activity_comment","friendship_accepted","friendship_created","created_group","joined_group","group_details_updated","wpforo_topic","wpforo_post","wpforo_like","new_blog_post","new_blog_comment"],"type":"string"},"required":false},"display_comments":{"description":"\u041f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0435\u0432 \u043d\u0435\u0442, \u043f\u043e\u0442\u043e\u043a \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0432 \u043f\u043e\u0442\u043e\u043a\u0435, \u043f\u043e\u0442\u043e\u043a \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u043f\u043e\u0434 \u043a\u0430\u0436\u0434\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f.","default":"","type":"string","required":false}}},{"methods":["POST"],"args":{"primary_item_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043a\u0430\u043a\u043e\u0433\u043e-\u043b\u0438\u0431\u043e \u0434\u0440\u0443\u0433\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u0432 \u043f\u0435\u0440\u0432\u0443\u044e \u043e\u0447\u0435\u0440\u0435\u0434\u044c \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u0441 \u044d\u0442\u0438\u043c.","type":"integer","required":false},"secondary_item_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043a\u0430\u043a\u043e\u0433\u043e-\u043b\u0438\u0431\u043e \u0434\u0440\u0443\u0433\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u0442\u0430\u043a\u0436\u0435 \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u0441 \u044d\u0442\u0438\u043c.","type":"integer","required":false},"link":{"description":"\u041f\u043e\u0441\u0442\u043e\u044f\u043d\u043d\u0430\u044f \u0441\u0441\u044b\u043b\u043a\u0430 \u043d\u0430 \u044d\u0442\u043e \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u0435 \u043d\u0430 \u0441\u0430\u0439\u0442\u0435.","type":"string","format":"uri","required":false},"component":{"description":"\u0410\u043a\u0442\u0438\u0432\u043d\u044b\u0439 \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442 BuddyPress, \u043a \u043a\u043e\u0442\u043e\u0440\u043e\u043c\u0443 \u043e\u0442\u043d\u043e\u0441\u0438\u0442\u0441\u044f \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u0435.","type":"string","enum":["xprofile","settings","friends","messages","activity","notifications","groups","blogs","members","members_invitations","community"],"required":false},"type":{"description":"\u0422\u0438\u043f \u0434\u0435\u044f\u0442\u0435\u043b\u044c\u043d\u043e\u0441\u0442\u0438.","type":"string","enum":["new_member","new_avatar","updated_profile","activity_update","activity_comment","friendship_accepted","friendship_created","created_group","joined_group","group_details_updated","wpforo_topic","wpforo_post","wpforo_like","new_blog_post","new_blog_comment"],"required":false},"content":{"description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0435\u043d\u043d\u043e\u0435 HTML-\u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0434\u043b\u044f \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f.","type":"string","required":false},"hidden":{"description":"\u0414\u043e\u043b\u0436\u0435\u043d \u043b\u0438 \u043e\u0431\u044a\u0435\u043a\u0442 \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f \u0431\u044b\u0442\u044c \u0441\u043a\u0440\u044b\u0442\u044b\u043c \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443 \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/activity"}]}},"\/buddypress\/v1\/activity\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f.","type":"integer","required":false},"primary_item_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043a\u0430\u043a\u043e\u0433\u043e-\u043b\u0438\u0431\u043e \u0434\u0440\u0443\u0433\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u0432 \u043f\u0435\u0440\u0432\u0443\u044e \u043e\u0447\u0435\u0440\u0435\u0434\u044c \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u0441 \u044d\u0442\u0438\u043c.","type":"integer","required":false},"secondary_item_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043a\u0430\u043a\u043e\u0433\u043e-\u043b\u0438\u0431\u043e \u0434\u0440\u0443\u0433\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u0442\u0430\u043a\u0436\u0435 \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u0441 \u044d\u0442\u0438\u043c.","type":"integer","required":false},"link":{"description":"\u041f\u043e\u0441\u0442\u043e\u044f\u043d\u043d\u0430\u044f \u0441\u0441\u044b\u043b\u043a\u0430 \u043d\u0430 \u044d\u0442\u043e \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u0435 \u043d\u0430 \u0441\u0430\u0439\u0442\u0435.","type":"string","format":"uri","required":false},"component":{"description":"\u0410\u043a\u0442\u0438\u0432\u043d\u044b\u0439 \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442 BuddyPress, \u043a \u043a\u043e\u0442\u043e\u0440\u043e\u043c\u0443 \u043e\u0442\u043d\u043e\u0441\u0438\u0442\u0441\u044f \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u0435.","type":"string","enum":["xprofile","settings","friends","messages","activity","notifications","groups","blogs","members","members_invitations","community"],"required":false},"type":{"description":"\u0422\u0438\u043f \u0434\u0435\u044f\u0442\u0435\u043b\u044c\u043d\u043e\u0441\u0442\u0438.","type":"string","enum":["new_member","new_avatar","updated_profile","activity_update","activity_comment","friendship_accepted","friendship_created","created_group","joined_group","group_details_updated","wpforo_topic","wpforo_post","wpforo_like","new_blog_post","new_blog_comment"],"required":true},"content":{"description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0435\u043d\u043d\u043e\u0435 HTML-\u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0434\u043b\u044f \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f.","type":"string","required":false},"hidden":{"description":"\u0414\u043e\u043b\u0436\u0435\u043d \u043b\u0438 \u043e\u0431\u044a\u0435\u043a\u0442 \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f \u0431\u044b\u0442\u044c \u0441\u043a\u0440\u044b\u0442\u044b\u043c \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443 \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f.","type":"integer","required":false}}}]},"\/buddypress\/v1\/activity\/(?P<id>[\\d]+)\/favorite":{"namespace":"buddypress\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f.","type":"integer","required":false}}}]},"\/buddypress\/v1\/friends":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430, \u0441\u043f\u0438\u0441\u043e\u043a \u0434\u0440\u0443\u0437\u0435\u0439 \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u0438\u0437\u0432\u043b\u0435\u043a\u0430\u0435\u0442\u0441\u044f.","default":0,"type":"integer","required":true},"is_confirmed":{"description":"\u0411\u044b\u043b\u0430 \u043b\u0438 \u0434\u0440\u0443\u0436\u0431\u0430 \u043f\u0440\u0438\u043d\u044f\u0442\u0430.","default":0,"type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u0440\u0443\u0436\u0431\u044b.","default":0,"type":"integer","required":false},"initiator_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u043f\u0440\u0435\u0434\u043b\u043e\u0436\u0438\u043b \u0434\u0440\u0443\u0436\u0431\u0443.","default":0,"type":"integer","required":false},"friend_id":{"description":"ID \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u043e\u043c\u0443 \u043f\u0440\u0435\u0434\u043b\u0430\u0433\u0430\u0435\u0442\u0441\u044f \u043f\u0440\u0438\u043d\u044f\u0442\u044c \u043f\u0440\u0435\u0434\u043b\u043e\u0436\u0435\u043d\u0438\u0435 \u0434\u0440\u0443\u0436\u0431\u044b.","default":0,"type":"integer","required":false},"order_by":{"description":"\u0418\u043c\u044f \u0441\u0442\u043e\u043b\u0431\u0446\u0430, \u043f\u043e \u043a\u043e\u0442\u043e\u0440\u043e\u043c\u0443 \u043d\u0443\u0436\u043d\u043e \u0443\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b.","default":"date_created","type":"string","enum":["date_created","initiator_user_id","friend_user_id","id"],"required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","default":"desc","type":"string","enum":["asc","desc"],"required":false}}},{"methods":["POST"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"edit","required":false},"initiator_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0437\u0430\u043f\u0440\u0430\u0448\u0438\u0432\u0430\u044e\u0449\u0435\u0433\u043e \u0434\u0440\u0443\u0436\u0431\u0443.","type":"integer","required":true},"friend_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u043e\u043c\u0443 \u043f\u0440\u0435\u0434\u043b\u0430\u0433\u0430\u0435\u0442\u0441\u044f \u0441\u043e\u0433\u043b\u0430\u0441\u0438\u0442\u044c\u0441\u044f \u043d\u0430 \u0437\u0430\u043f\u0440\u043e\u0441 \u043e \u0434\u0440\u0443\u0436\u0431\u0435.","type":"integer","required":true},"force":{"description":"\u0421\u0442\u043e\u0438\u0442 \u043b\u0438 \u0430\u0432\u0442\u043e\u043c\u0430\u0442\u0438\u0447\u0435\u0441\u043a\u0438 \u043f\u0440\u0438\u043d\u0438\u043c\u0430\u0442\u044c \u043f\u0440\u0435\u0434\u043b\u043e\u0436\u0435\u043d\u0438\u0435 \u043e \u0434\u0440\u0443\u0436\u0431\u0435.","default":false,"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/friends"}]}},"\/buddypress\/v1\/friends\/(?P<id>[\\w-]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":true},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":true},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"edit","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":true},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"edit","required":false},"force":{"description":"\u0421\u0442\u043e\u0438\u0442 \u043b\u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c \u0434\u0440\u0443\u0436\u0431\u0443.","default":false,"type":"boolean","required":false}}}]},"\/buddypress\/v1\/groups":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"type":{"description":"\u0421\u043e\u043a\u0440\u0430\u0449\u0435\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u043a\u043e\u043c\u0431\u0438\u043d\u0430\u0446\u0438\u0439 \u0437\u0430\u043a\u0430\u0437\u0430\/\u0437\u0430\u043a\u0430\u0437\u0430.","default":"active","type":"string","enum":["active","newest","alphabetical","random","popular"],"required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","default":"desc","type":"string","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0433\u0440\u0443\u043f\u043f\u044b \u043f\u043e \u043a\u0430\u043a\u043e\u043c\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443.","default":"date_created","type":"string","enum":["date_created","last_activity","total_member_count","name","random"],"required":false},"status":{"description":"\u0413\u0440\u0443\u043f\u043f\u0438\u0440\u0443\u0439\u0442\u0435 \u0441\u0442\u0430\u0442\u0443\u0441\u044b, \u043a\u043e\u0442\u043e\u0440\u044b\u043c\u0438 \u043c\u043e\u0436\u043d\u043e \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b.","default":[],"type":"array","items":{"enum":["public","private","hidden"],"type":"string"},"required":false},"user_id":{"description":"\u041f\u0435\u0440\u0435\u0434\u0430\u0439\u0442\u0435 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0447\u0442\u043e\u0431\u044b \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0434\u043e\u0441\u0442\u0443\u043f \u0442\u043e\u043b\u044c\u043a\u043e \u043a \u0433\u0440\u0443\u043f\u043f\u0430\u043c, \u0447\u043b\u0435\u043d\u043e\u043c \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u044d\u0442\u043e\u0442 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c.","default":0,"type":"integer","required":false},"parent_id":{"description":"\u041f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u0433\u0440\u0443\u043f\u043f\u044b, \u044f\u0432\u043b\u044f\u044e\u0449\u0438\u0435\u0441\u044f \u0434\u043e\u0447\u0435\u0440\u043d\u0438\u043c\u0438 \u0434\u043b\u044f \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u0445 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u043e\u0432 \u0433\u0440\u0443\u043f\u043f.","default":[],"type":"array","items":{"type":"integer"},"required":false},"meta":{"description":"\u041f\u043e\u043b\u0443\u0447\u0438\u0442\u0435 \u0433\u0440\u0443\u043f\u043f\u044b \u043d\u0430 \u043e\u0441\u043d\u043e\u0432\u0435 \u0438\u0445 \u043c\u0435\u0442\u0430\u0434\u0430\u043d\u043d\u044b\u0445.","default":[],"type":"array","items":{"type":"string"},"required":false},"include":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0432\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u0433\u0440\u0443\u043f\u043f\u044b \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u0430\u043c\u0438.","default":[],"type":"array","items":{"type":"integer"},"required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u0433\u0440\u0443\u043f\u043f\u044b \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u0430\u043c\u0438","default":[],"type":"array","items":{"type":"integer"},"required":false},"group_type":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b, \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u0435 \u0434\u043b\u044f \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u0442\u0438\u043f\u0430 \u0433\u0440\u0443\u043f\u043f\u044b.","default":"","type":"string","enum":[],"required":false},"enable_forum":{"description":"\u041d\u0435\u0437\u0430\u0432\u0438\u0441\u0438\u043c\u043e \u043e\u0442 \u0442\u043e\u0433\u043e, \u0432\u043a\u043b\u044e\u0447\u0435\u043d \u043b\u0438 \u0432 \u0433\u0440\u0443\u043f\u043f\u0435 \u0444\u043e\u0440\u0443\u043c.","default":false,"type":"boolean","required":false},"show_hidden":{"description":"\u0414\u043e\u043b\u0436\u043d\u044b \u043b\u0438 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0432\u043a\u043b\u044e\u0447\u0430\u0442\u044c \u0441\u043a\u0440\u044b\u0442\u044b\u0435 \u0433\u0440\u0443\u043f\u043f\u044b.","default":false,"type":"boolean","required":false},"populate_extras":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0434\u043e\u043f\u043e\u043b\u043d\u0438\u0442\u0435\u043b\u044c\u043d\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 BP \u043e \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043d\u044b\u0445 \u0433\u0440\u0443\u043f\u043f\u0430\u0445.","default":false,"type":"boolean","required":false}}},{"methods":["POST"],"args":{"creator_id":{"default":0,"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0441\u043e\u0437\u0434\u0430\u0432\u0448\u0435\u0433\u043e \u0433\u0440\u0443\u043f\u043f\u0443.","type":"integer","required":false},"name":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"string","required":true},"slug":{"description":"\u0414\u0440\u0443\u0436\u0435\u0441\u0442\u0432\u0435\u043d\u043d\u044b\u0439 \u043a URL \u044f\u0440\u043b\u044b\u043a \u0433\u0440\u0443\u043f\u043f\u044b.","type":"string","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"string","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u044f \u0413\u0440\u0443\u043f\u043f\u044b \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d\u0430 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 HTML \u0434\u043b\u044f \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u044f \u0433\u0440\u0443\u043f\u043f\u044b, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":true},"status":{"default":"public","description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0413\u0440\u0443\u043f\u043f\u044b.","type":"string","enum":["public","private","hidden"],"required":false},"enable_forum":{"description":"\u041d\u0435\u0437\u0430\u0432\u0438\u0441\u0438\u043c\u043e \u043e\u0442 \u0442\u043e\u0433\u043e, \u0432\u043a\u043b\u044e\u0447\u0435\u043d \u043b\u0438 \u0432 \u0433\u0440\u0443\u043f\u043f\u0435 \u0444\u043e\u0440\u0443\u043c.","type":"boolean","required":false},"parent_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0439 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false},"types":{"description":"\u041d\u0430\u0437\u043d\u0430\u0447\u044c\u0442\u0435 \u0433\u0440\u0443\u043f\u043f\u0435 \u043e\u0434\u0438\u043d \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u043e \u0442\u0438\u043f\u043e\u0432. \u0427\u0442\u043e\u0431\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0431\u043e\u043b\u0435\u0435 \u043e\u0434\u043d\u043e\u0433\u043e \u0442\u0438\u043f\u0430, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u0441\u043f\u0438\u0441\u043e\u043a \u0442\u0438\u043f\u043e\u0432, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438.","type":"string","enum":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/groups"}]}},"\/buddypress\/v1\/groups\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"populate_extras":{"description":"\u041d\u0443\u0436\u043d\u043e \u043b\u0438 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u044c \u0434\u043e\u043f\u043e\u043b\u043d\u0438\u0442\u0435\u043b\u044c\u043d\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 BP \u043e \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043d\u043e\u0439 \u0433\u0440\u0443\u043f\u043f\u0435.","default":false,"type":"boolean","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false},"creator_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0441\u043e\u0437\u0434\u0430\u0432\u0448\u0435\u0433\u043e \u0433\u0440\u0443\u043f\u043f\u0443.","type":"integer","required":false},"name":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"string","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"string","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u044f \u0413\u0440\u0443\u043f\u043f\u044b \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d\u0430 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 HTML \u0434\u043b\u044f \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u044f \u0433\u0440\u0443\u043f\u043f\u044b, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"status":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0413\u0440\u0443\u043f\u043f\u044b.","type":"string","enum":["public","private","hidden"],"required":false},"enable_forum":{"description":"\u041d\u0435\u0437\u0430\u0432\u0438\u0441\u0438\u043c\u043e \u043e\u0442 \u0442\u043e\u0433\u043e, \u0432\u043a\u043b\u044e\u0447\u0435\u043d \u043b\u0438 \u0432 \u0433\u0440\u0443\u043f\u043f\u0435 \u0444\u043e\u0440\u0443\u043c.","type":"boolean","required":false},"parent_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0439 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false},"types":{"description":"\u041d\u0430\u0437\u043d\u0430\u0447\u044c\u0442\u0435 \u0433\u0440\u0443\u043f\u043f\u0435 \u043e\u0434\u0438\u043d \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u043e \u0442\u0438\u043f\u043e\u0432. \u0427\u0442\u043e\u0431\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0431\u043e\u043b\u0435\u0435 \u043e\u0434\u043d\u043e\u0433\u043e \u0442\u0438\u043f\u0430, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u0441\u043f\u0438\u0441\u043e\u043a \u0442\u0438\u043f\u043e\u0432, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438.","type":"string","enum":[],"required":false},"append_types":{"description":"\u0414\u043e\u0431\u0430\u0432\u044c\u0442\u0435 \u043e\u0434\u0438\u043d \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u043e \u0442\u0438\u043f\u043e\u0432 \u0432 \u0433\u0440\u0443\u043f\u043f\u0443. \u0427\u0442\u043e\u0431\u044b \u0434\u043e\u0431\u0430\u0432\u0438\u0442\u044c \u0431\u043e\u043b\u0435\u0435 \u043e\u0434\u043d\u043e\u0433\u043e \u0442\u0438\u043f\u0430, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u0441\u043f\u0438\u0441\u043e\u043a \u0442\u0438\u043f\u043e\u0432, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438.","type":"string","enum":[],"required":false},"remove_types":{"description":"\u0423\u0434\u0430\u043b\u0438\u0442\u0435 \u043e\u0434\u0438\u043d \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u043e \u0442\u0438\u043f\u043e\u0432 \u0438\u0437 \u0433\u0440\u0443\u043f\u043f\u044b. \u0427\u0442\u043e\u0431\u044b \u0443\u0434\u0430\u043b\u0438\u0442\u044c \u0431\u043e\u043b\u0435\u0435 \u043e\u0434\u043d\u043e\u0433\u043e \u0442\u0438\u043f\u0430, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u0441\u043f\u0438\u0441\u043e\u043a \u0442\u0438\u043f\u043e\u0432, \u0440\u0430\u0437\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u044f\u0442\u044b\u043c\u0438.","type":"string","enum":[],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false}}}]},"\/buddypress\/v1\/groups\/me":{"namespace":"buddypress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"max":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u043a\u043e\u043b\u0438\u0447\u0435\u0441\u0442\u0432\u043e \u0433\u0440\u0443\u043f\u043f, \u0447\u043b\u0435\u043d\u043e\u043c \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c, \u0434\u043b\u044f \u0432\u043e\u0437\u0432\u0440\u0430\u0442\u0430. \u041f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u0442\u0441\u044f \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435 \"\u0432\u0441\u0435 \u0433\u0440\u0443\u043f\u043f\u044b\".","type":"integer","default":0,"required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/groups\/me"}]}},"\/buddypress\/v1\/groups\/(?P<group_id>[\\d]+)\/members":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"status":{"description":"\u041e\u0442\u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u043f\u043e \u0441\u0442\u0430\u0442\u0443\u0441\u0443 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u043e\u0432 \u0433\u0440\u0443\u043f\u043f\u044b.","default":"last_joined","type":"string","enum":["last_joined","first_joined","alphabetical","group_activity"],"required":false},"roles":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0432\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0440\u043e\u043b\u0438 \u0433\u0440\u0443\u043f\u043f\u044b.","default":[],"type":"array","items":{"type":"string","enum":["admin","mod","member","banned"]},"required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u0435\u0441\u044c, \u0447\u0442\u043e \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u043e\u0432.","default":[],"type":"array","items":{"type":"integer"},"required":false},"exclude_admins":{"description":"\u0414\u043e\u043b\u0436\u043d\u044b \u043b\u0438 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0442\u044c \u0430\u0434\u043c\u0438\u043d\u0438\u0441\u0442\u0440\u0430\u0442\u043e\u0440\u043e\u0432 \u0433\u0440\u0443\u043f\u043f \u0438 \u043c\u043e\u0434\u043e\u0432.","default":true,"type":"boolean","required":false},"exclude_banned":{"description":"\u0414\u043e\u043b\u0436\u043d\u044b \u043b\u0438 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0442\u044c \u0437\u0430\u043f\u0440\u0435\u0449\u0435\u043d\u043d\u044b\u0445 \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u043e\u0432 \u0433\u0440\u0443\u043f\u043f\u044b.","default":true,"type":"boolean","required":false}}},{"methods":["POST"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"edit","required":false},"role":{"description":"\u0420\u043e\u043b\u044c \u0433\u0440\u0443\u043f\u043f\u044b, \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u043d\u0443\u0436\u043d\u043e \u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","default":"member","type":"string","enum":["admin","mod","member"],"required":false},"user_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0443\u0447\u0430\u0441\u0442\u043d\u0438\u043a\u0430, \u0434\u043e\u0431\u0430\u0432\u043b\u044f\u0435\u043c\u043e\u0433\u043e \u0432 \u0433\u0440\u0443\u043f\u043f\u0443.","type":"integer","default":0,"required":true}}}]},"\/buddypress\/v1\/groups\/(?P<group_id>[\\d]+)\/members\/(?P<user_id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"edit","required":false},"role":{"description":"\u0420\u043e\u043b\u044c \u0433\u0440\u0443\u043f\u043f\u044b, \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u043d\u0443\u0436\u043d\u043e \u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","default":"member","type":"string","enum":["admin","mod","member"],"required":false},"action":{"description":"\u0414\u0435\u0439\u0441\u0442\u0432\u0438\u0435, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u043e\u0435 \u0434\u043b\u044f \u043e\u0431\u043d\u043e\u0432\u043b\u0435\u043d\u0438\u044f \u0447\u043b\u0435\u043d\u0430 \u0433\u0440\u0443\u043f\u043f\u044b.","default":"promote","type":"string","enum":["promote","demote","ban","unban"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"edit","required":false}}}]},"\/buddypress\/v1\/groups\/invites":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b, \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u043d\u0443\u0436\u043d\u043e \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b.","default":0,"type":"integer","required":false},"user_id":{"description":"\u0412\u0435\u0440\u043d\u0443\u0442\u044c \u0442\u043e\u043b\u044c\u043a\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u044f, \u043e\u0442\u043f\u0440\u0430\u0432\u043b\u0435\u043d\u043d\u044b\u0435 \u044d\u0442\u043e\u043c\u0443 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044e.","default":0,"type":"integer","required":false},"inviter_id":{"description":"\u0412\u0435\u0440\u043d\u0443\u0442\u044c \u0442\u043e\u043b\u044c\u043a\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u044f, \u043e\u0442\u043f\u0440\u0430\u0432\u043b\u0435\u043d\u043d\u044b\u0435 \u044d\u0442\u0438\u043c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u043c.","default":0,"type":"integer","required":false},"invite_sent":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u044f\u043c\u0438, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u0431\u044b\u043b\u0438 \u043e\u0442\u043f\u0440\u0430\u0432\u043b\u0435\u043d\u044b, \u043d\u0435 \u043e\u0442\u043f\u0440\u0430\u0432\u043b\u0435\u043d\u044b \u0438\u043b\u0438 \u0432\u043a\u043b\u044e\u0447\u0438\u0442\u044c \u0432\u0441\u0435.","default":"sent","type":"string","enum":["draft","sent","all"],"required":false}}},{"methods":["POST"],"args":{"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0430\u044e\u0442 \u043f\u0440\u0438\u0441\u043e\u0435\u0434\u0438\u043d\u0438\u0442\u044c\u0441\u044f \u043a \u0433\u0440\u0443\u043f\u043f\u0435.","type":"integer","required":true},"inviter_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043e\u0442\u043f\u0440\u0430\u0432\u0438\u0432\u0448\u0435\u0433\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u0435.","type":"integer","default":0,"required":false},"group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b, \u0432 \u043a\u043e\u0442\u043e\u0440\u0443\u044e \u0431\u044b\u043b \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c.","type":"integer","required":true},"message":{"description":"\u041d\u0435\u043e\u0431\u044f\u0437\u0430\u0442\u0435\u043b\u044c\u043d\u043e\u0435 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0442\u043f\u0440\u0430\u0432\u043a\u0438 \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u043d\u043e\u043c\u0443 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044e.","type":"string","default":"","required":false},"send_invite":{"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u043b\u0438 \u0431\u044b\u0442\u044c \u043e\u0442\u043f\u0440\u0430\u0432\u043b\u0435\u043d\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u0435 \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0430\u0435\u043c\u043e\u043c\u0443.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/groups\/invites"}]}},"\/buddypress\/v1\/groups\/invites\/(?P<invite_id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"invite_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0440\u0443\u043f\u043f\u043e\u0432\u043e\u0433\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"invite_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0440\u0443\u043f\u043f\u043e\u0432\u043e\u0433\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u044f.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"invite_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0440\u0443\u043f\u043f\u043e\u0432\u043e\u0433\u043e \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u0438\u044f.","type":"integer","required":false}}}]},"\/buddypress\/v1\/groups\/membership-requests":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b, \u0447\u043b\u0435\u043d\u0441\u0442\u0432\u043e \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u0437\u0430\u043f\u0440\u043e\u0441\u0438\u043b \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c.","default":0,"type":"integer","required":false},"user_id":{"description":"\u0412\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0442\u044c \u0442\u043e\u043b\u044c\u043a\u043e \u0437\u0430\u043f\u0440\u043e\u0441\u044b \u043d\u0430 \u0447\u043b\u0435\u043d\u0441\u0442\u0432\u043e, \u0441\u0434\u0435\u043b\u0430\u043d\u043d\u044b\u0435 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u043c.","default":0,"type":"integer","required":false}}},{"methods":["POST"],"args":{"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0437\u0430\u043f\u0440\u043e\u0441\u0438\u0432\u0448\u0435\u0433\u043e \u0447\u043b\u0435\u043d\u0441\u0442\u0432\u043e \u0432 \u0433\u0440\u0443\u043f\u043f\u0435.","type":"integer","default":0,"required":false},"group_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b, \u0447\u043b\u0435\u043d\u0441\u0442\u0432\u043e \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u0437\u0430\u043f\u0440\u043e\u0441\u0438\u043b \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c.","type":"integer","required":true},"message":{"description":"\u041d\u0435\u043e\u0431\u044f\u0437\u0430\u0442\u0435\u043b\u044c\u043d\u043e\u0435 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0442\u043f\u0440\u0430\u0432\u043a\u0438 \u043f\u0440\u0438\u0433\u043b\u0430\u0448\u0435\u043d\u043d\u043e\u043c\u0443 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044e.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/groups\/membership-requests"}]}},"\/buddypress\/v1\/groups\/membership-requests\/(?P<request_id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"request_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0440\u043e\u0441\u0430 \u043d\u0430 \u0447\u043b\u0435\u043d\u0441\u0442\u0432\u043e \u0432 \u0433\u0440\u0443\u043f\u043f\u0435.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"request_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0440\u043e\u0441\u0430 \u043d\u0430 \u0447\u043b\u0435\u043d\u0441\u0442\u0432\u043e \u0432 \u0433\u0440\u0443\u043f\u043f\u0435.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"request_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0440\u043e\u0441\u0430 \u043d\u0430 \u0447\u043b\u0435\u043d\u0441\u0442\u0432\u043e \u0432 \u0433\u0440\u0443\u043f\u043f\u0435.","type":"integer","required":false}}}]},"\/buddypress\/v1\/groups\/(?P<group_id>[\\d]+)\/avatar":{"namespace":"buddypress\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"group_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"html":{"description":"\u0412\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0442\u044c \u043b\u0438 HTML-\u044d\u043b\u0435\u043c\u0435\u043d\u0442 <img> \u0438\u043b\u0438 \u043d\u0435\u043e\u0431\u0440\u0430\u0431\u043e\u0442\u0430\u043d\u043d\u044b\u0439 URL-\u0430\u0434\u0440\u0435\u0441 \u0430\u0432\u0430\u0442\u0430\u0440\u0430 \u0433\u0440\u0443\u043f\u043f\u044b.","default":false,"type":"boolean","required":false},"alt":{"description":"\u0410\u0442\u0440\u0438\u0431\u0443\u0442 alt \u0434\u043b\u044f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 <img>.","default":"","type":"string","required":false}}},{"methods":["POST"],"args":{"group_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"group_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false}}}]},"\/buddypress\/v1\/groups\/(?P<group_id>[\\d]+)\/cover":{"namespace":"buddypress\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"group_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false}}},{"methods":["POST"],"args":{"group_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"group_id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0433\u0440\u0443\u043f\u043f\u044b.","type":"integer","required":false}}}]},"\/buddypress\/v1\/messages":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"box":{"description":"\u041e\u0442\u0444\u0438\u043b\u044c\u0442\u0440\u043e\u0432\u0430\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442 \u043f\u043e \u043f\u043e\u043b\u044e.","default":"inbox","type":"string","enum":["sentbox","inbox","starred"],"required":false},"type":{"description":"\u041e\u0442\u0444\u0438\u043b\u044c\u0442\u0440\u043e\u0432\u0430\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442 \u043f\u043e \u0441\u0442\u0430\u0442\u0443\u0441\u0443 \u043f\u043e\u0442\u043e\u043a\u0430.","default":"all","type":"string","enum":["all","read","unread"],"required":false},"user_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f\u043c\u0438, \u0441\u043e\u0437\u0434\u0430\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u043c.","default":0,"type":"integer","required":true},"recipients_page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u0441\u043f\u0438\u0441\u043a\u0430 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u0435\u043b\u0435\u0439.","type":"integer","default":1,"minimum":1,"required":false},"recipients_per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u043a\u043e\u043b\u0438\u0447\u0435\u0441\u0442\u0432\u043e \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u0435\u043b\u0435\u0439, \u043a\u043e\u0442\u043e\u0440\u043e\u0435 \u0434\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043e \u0432 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u0430\u0445.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"messages_page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439.","type":"integer","default":1,"minimum":1,"required":false},"messages_per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u043a\u043e\u043b\u0438\u0447\u0435\u0441\u0442\u0432\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439, \u043a\u043e\u0442\u043e\u0440\u043e\u0435 \u0434\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043e \u0432 \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u0442\u043e\u043a\u0430 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439. \u0422\u0440\u0435\u0431\u0443\u0435\u0442\u0441\u044f \u043f\u0440\u0438 \u043e\u0442\u0432\u0435\u0442\u0435 \u043d\u0430 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u044e\u0449\u0438\u0439 \u043f\u043e\u0442\u043e\u043a.","type":"integer","default":0,"required":false},"subject":{"description":"\u0422\u0435\u043c\u0430 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f, \u0438\u043d\u0438\u0446\u0438\u0430\u043b\u0438\u0437\u0438\u0440\u0443\u044e\u0449\u0435\u0433\u043e \u043f\u043e\u0442\u043e\u043a.","type":"string","default":false,"required":false},"message":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u0434\u043b\u044f \u0434\u043e\u0431\u0430\u0432\u043b\u0435\u043d\u0438\u044f \u0432 \u0442\u0435\u043c\u0443.","type":"string","required":true},"recipients":{"description":"\u0421\u043f\u0438\u0441\u043e\u043a \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u043e\u0432 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u0435\u043b\u0435\u0439 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f.","type":"array","items":{"type":"integer"},"required":true},"sender_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f \u043e\u0442\u043f\u0440\u0430\u0432\u0438\u0442\u0435\u043b\u044f \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f.","default":0,"type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/messages"}]}},"\/buddypress\/v1\/messages\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u0442\u043e\u043a\u0430 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439.","type":"integer","required":false},"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0434\u043b\u044f \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e \u043f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u043f\u043e\u0442\u043e\u043a.","type":"integer","required":false},"recipients_page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u0441\u043f\u0438\u0441\u043a\u0430 \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u0435\u043b\u0435\u0439.","type":"integer","default":1,"minimum":1,"required":false},"recipients_per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u043a\u043e\u043b\u0438\u0447\u0435\u0441\u0442\u0432\u043e \u043f\u043e\u043b\u0443\u0447\u0430\u0442\u0435\u043b\u0435\u0439, \u043a\u043e\u0442\u043e\u0440\u043e\u0435 \u0434\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043e \u0432 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u0430\u0445.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"messages_page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439.","type":"integer","default":1,"minimum":1,"required":false},"messages_per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u043a\u043e\u043b\u0438\u0447\u0435\u0441\u0442\u0432\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439, \u043a\u043e\u0442\u043e\u0440\u043e\u0435 \u0434\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0435\u043d\u043e \u0432 \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","default":"asc","type":"string","enum":["asc","desc"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u0442\u043e\u043a\u0430 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439.","type":"integer","required":false},"subject":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0435\u0433\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u0432 \u0442\u0435\u043c\u0435.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0435\u0433\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u0442\u0435\u043c\u044b \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"],"default":false},"rendered":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0435\u0433\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u0432 \u0442\u0435\u043c\u0435, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"string","context":["view","edit"],"readonly":true,"default":false}},"required":false},"message":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0435\u0433\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u0442\u0435\u043c\u044b.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0435\u0433\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u043f\u043e\u0442\u043e\u043a\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 HTML \u0434\u043b\u044f \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0435\u0433\u043e \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f \u0432 \u0442\u0435\u043c\u0435, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"recipients":{"description":"\u0421\u043f\u0438\u0441\u043e\u043a \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c\u0441\u043a\u0438\u0445 \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432-\u043f\u043e\u043b\u0443\u0447\u0430\u0442\u0435\u043b\u0435\u0439, \u0443\u0447\u0430\u0441\u0442\u0432\u0443\u044e\u0449\u0438\u0445 \u0432 \u043f\u043e\u0442\u043e\u043a\u0435.","type":"array","items":{"type":"object"},"required":false},"read":{"description":"\u041e\u0442\u043c\u0435\u0442\u0438\u0442\u044c \u043b\u0438 \u0442\u0435\u043c\u0443 \u043a\u0430\u043a \u043f\u0440\u043e\u0447\u0438\u0442\u0430\u043d\u043d\u0443\u044e.","default":false,"type":"boolean","required":false},"unread":{"description":"\u041e\u0442\u043c\u0435\u0442\u0438\u0442\u044c \u043b\u0438 \u0442\u0435\u043c\u0443 \u043a\u0430\u043a \u043d\u0435\u043f\u0440\u043e\u0447\u0438\u0442\u0430\u043d\u043d\u0443\u044e.","default":false,"type":"boolean","required":false},"message_id":{"description":"\u041f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e \u0431\u0443\u0434\u0435\u0442 \u043e\u0431\u043d\u043e\u0432\u043b\u0435\u043d\u043e \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0435\u0435 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0435 \u0432 \u043f\u043e\u0442\u043e\u043a\u0435. \u0423\u043a\u0430\u0436\u0438\u0442\u0435 \u044d\u0442\u043e\u0442 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u044f, \u0447\u0442\u043e\u0431\u044b \u043e\u0442\u0440\u0435\u0434\u0430\u043a\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0434\u0440\u0443\u0433\u043e\u0435 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0435 \u0432 \u043f\u043e\u0442\u043e\u043a\u0435.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u0442\u043e\u043a\u0430 \u0441\u043e\u043e\u0431\u0449\u0435\u043d\u0438\u0439.","type":"integer","required":false},"user_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043d\u0443\u0436\u043d\u043e \u0443\u0434\u0430\u043b\u0438\u0442\u044c \u0438\u0437 \u0432\u0435\u0442\u043a\u0438.","type":"integer","default":0,"required":true}}}]},"\/buddypress\/v1\/messages\/starred\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/buddypress\/v1\/sitewide-notices":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443. \u0422\u0440\u0435\u0431\u0443\u0435\u0442\u0441\u044f \u043f\u0440\u0438 \u0440\u0435\u0434\u0430\u043a\u0442\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u0438 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u044e\u0449\u0435\u0433\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"integer","default":0,"required":false},"subject":{"description":"\u0422\u0435\u043c\u0430 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u0434\u043b\u044f \u0432\u0441\u0435\u0433\u043e \u0441\u0430\u0439\u0442\u0430.","type":"string","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u044f\u0432\u043b\u0435\u043d\u0438\u044f \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"],"default":false},"rendered":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u044f\u0432\u043b\u0435\u043d\u0438\u044f \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"string","context":["view","edit"],"readonly":true,"default":false}},"default":false,"required":false},"message":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u0435 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u0434\u043b\u044f \u0432\u0441\u0435\u0433\u043e \u0441\u0430\u0439\u0442\u0430.","type":"string","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u0434\u043b\u044f \u0432\u0441\u0435\u0433\u043e \u0441\u0430\u0439\u0442\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 HTML \u0434\u043b\u044f \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"string","context":["view","edit"],"readonly":true}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/sitewide-notices"}]}},"\/buddypress\/v1\/sitewide-notices\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u0434\u043b\u044f \u0432\u0441\u0435\u0433\u043e \u0441\u0430\u0439\u0442\u0430.","type":"integer","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043e\u0431\u043d\u043e\u0432\u043b\u044f\u0435\u043c\u043e\u0433\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443. \u0422\u0440\u0435\u0431\u0443\u0435\u0442\u0441\u044f \u043f\u0440\u0438 \u0440\u0435\u0434\u0430\u043a\u0442\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u0438 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u044e\u0449\u0435\u0433\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"integer","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0434\u0430\u043b\u044f\u0435\u043c\u043e\u0433\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u043f\u043e \u0432\u0441\u0435\u043c\u0443 \u0441\u0430\u0439\u0442\u0443. \u0422\u0440\u0435\u0431\u0443\u0435\u0442\u0441\u044f \u043f\u0440\u0438 \u0443\u0434\u0430\u043b\u0435\u043d\u0438\u0438 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u044e\u0449\u0435\u0433\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"integer","required":true}}}]},"\/buddypress\/v1\/sitewide-notices\/dismiss":{"namespace":"buddypress\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/sitewide-notices\/dismiss"}]}},"\/buddypress\/v1\/notifications":{"namespace":"buddypress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order_by":{"description":"\u0418\u043c\u044f \u043f\u043e\u043b\u044f \u0434\u043b\u044f \u0437\u0430\u043a\u0430\u0437\u0430.","default":"id","type":"string","enum":["id","date_notified","item_id","secondary_item_id","component_name","component_action"],"required":false},"sort_order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","default":"ASC","type":"string","enum":["ASC","DESC"],"required":false},"component_name":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f\u043c\u0438, \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u044b\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442\u043e\u043c.","default":"","type":"string","required":false},"component_action":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f\u043c\u0438, \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u044b\u043c\u0438 \u0441 \u0438\u043c\u0435\u043d\u0435\u043c \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442\u0430.","default":"","type":"string","required":false},"user_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f\u043c\u0438, \u0430\u0434\u0440\u0435\u0441\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u043e\u043c\u0443 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044e.","default":0,"type":"integer","required":false},"user_ids":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f\u043c\u0438, \u0430\u0434\u0440\u0435\u0441\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0441\u043f\u0438\u0441\u043a\u0443 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u0445 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439.","default":[],"type":"array","items":{"type":"integer"},"required":false},"item_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f\u043c\u0438, \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u044b\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u043e\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","default":0,"type":"integer","required":false},"secondary_item_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f\u043c\u0438, \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u044b\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u043e\u043c \u0432\u0442\u043e\u0440\u0438\u0447\u043d\u043e\u0433\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","default":0,"type":"integer","required":false},"is_new":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0438\u0437 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u0448\u0442\u0430\u0442\u043e\u0432.","default":true,"type":"boolean","required":false}}},{"methods":["POST"],"args":{"user_id":{"default":0,"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u043a\u043e\u0442\u043e\u0440\u043e\u043c\u0443 \u0430\u0434\u0440\u0435\u0441\u043e\u0432\u0430\u043d\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u0435.","type":"integer","required":false},"item_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430, \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u0441 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u0435\u043c.","type":"integer","required":false},"secondary_item_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0432\u0442\u043e\u0440\u0438\u0447\u043d\u043e\u0433\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430, \u0441\u0432\u044f\u0437\u0430\u043d\u043d\u043e\u0433\u043e \u0441 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u0435\u043c.","type":"integer","required":false},"component":{"description":"\u0418\u043c\u044f \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442\u0430 BuddyPress, \u043a \u043a\u043e\u0442\u043e\u0440\u043e\u043c\u0443 \u043e\u0442\u043d\u043e\u0441\u0438\u0442\u0441\u044f \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u0435.","type":"string","required":false},"action":{"description":"\u0418\u043c\u044f \u0434\u0435\u0439\u0441\u0442\u0432\u0438\u044f \u043a\u043e\u043c\u043f\u043e\u043d\u0435\u043d\u0442\u0430, \u043e \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u0438\u0434\u0435\u0442 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u0435.","type":"string","required":false},"is_new":{"default":1,"description":"\u041d\u0435\u0437\u0430\u0432\u0438\u0441\u0438\u043c\u043e \u043e\u0442 \u0442\u043e\u0433\u043e, \u043d\u043e\u0432\u043e\u0435 \u044d\u0442\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u0435 \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/buddypress\/v1\/notifications"}]}},"\/buddypress\/v1\/notifications\/(?P<id>[\\d]+)":{"namespace":"buddypress\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"integer","required":false},"is_new":{"description":"\u041d\u0435\u0437\u0430\u0432\u0438\u0441\u0438\u043c\u043e \u043e\u0442 \u0442\u043e\u0433\u043e, \u043d\u043e\u0432\u043e\u0435 \u044d\u0442\u043e \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u0435 \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"integer","default":0,"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0447\u0438\u0441\u043b\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"integer","required":false}}}]},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b. ","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"author":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u0430\u0432\u0442\u043e\u0440\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0430\u0432\u0442\u043e\u0440\u0430\u043c.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0441\u0442\u0430\u0442\u0443\u0441\u0430\u043c\u0438.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u043e\u0441\u043d\u043e\u0432\u044b\u0432\u0430\u044f\u0441\u044c \u043d\u0430 \u043e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u044f\u0445 \u043c\u0435\u0436\u0434\u0443 \u043c\u043d\u043e\u0436\u0435\u0441\u0442\u0432\u0435\u043d\u043d\u044b\u043c\u0438 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f\u043c\u0438.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 categories.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0438\u0442\u044c \u0432\u043a\u043b\u044e\u0447\u0430\u0442\u044c \u0434\u043e\u0447\u0435\u0440\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0432 \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u0438\u0435 \u0441\u043f\u0438\u0441\u043a\u0430 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432.","type":"boolean","default":false},"operator":{"description":"\u041f\u0440\u0438\u043d\u0430\u0434\u043b\u0435\u0436\u043d\u043e\u0441\u0442\u044c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u043a\u043e \u0432\u0441\u0435\u043c \u0438\u043b\u0438 \u043b\u044e\u0431\u043e\u043c\u0443 \u0438\u0437 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u0445 \u0442\u0435\u0440\u043c\u0438\u043d\u043e\u0432.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 categories.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0438\u0442\u044c \u0432\u043a\u043b\u044e\u0447\u0430\u0442\u044c \u0434\u043e\u0447\u0435\u0440\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0432 \u043e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u0438\u0435 \u0441\u043f\u0438\u0441\u043a\u0430 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 tags.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u041f\u0440\u0438\u043d\u0430\u0434\u043b\u0435\u0436\u043d\u043e\u0441\u0442\u044c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u043a\u043e \u0432\u0441\u0435\u043c \u0438\u043b\u0438 \u043b\u044e\u0431\u043e\u043c\u0443 \u0438\u0437 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u0445 \u0442\u0435\u0440\u043c\u0438\u043d\u043e\u0432.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 tags.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043f\u0440\u0438\u043b\u0435\u043f\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u0431\u044a\u0435\u043a\u0442\u0430\u043c\u0438.","type":"boolean","required":false},"ignore_sticky":{"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0440\u0438\u043a\u0440\u0435\u043f\u043b\u0435\u043d\u043d\u044b\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"boolean","default":true,"required":false},"format":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438, \u043a\u043e\u0442\u043e\u0440\u044b\u043c \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d \u043e\u0434\u0438\u043d \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u044b\u0445 \u0444\u043e\u0440\u043c\u0430\u0442\u043e\u0432.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u0424\u043e\u0440\u043c\u0430\u0442 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u0421\u0447\u0438\u0442\u0430\u0442\u044c \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u043f\u0440\u0438\u043b\u0435\u043f\u043b\u0435\u043d\u043d\u043e\u0439 \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"boolean","required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"categories":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u041f\u0435\u0440\u0435\u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0438\u0442\u044c \u0434\u043b\u0438\u043d\u0443 \u043e\u0442\u0440\u044b\u0432\u043a\u0430 \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e.","type":"integer","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0435\u0441\u043b\u0438 \u043e\u043d\u0430 \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u0424\u043e\u0440\u043c\u0430\u0442 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u0421\u0447\u0438\u0442\u0430\u0442\u044c \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u043f\u0440\u0438\u043b\u0435\u043f\u043b\u0435\u043d\u043d\u043e\u0439 \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"boolean","required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"categories":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443. ","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u0424\u043e\u0440\u043c\u0430\u0442 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u0421\u0447\u0438\u0442\u0430\u0442\u044c \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u043f\u0440\u0438\u043b\u0435\u043f\u043b\u0435\u043d\u043d\u043e\u0439 \u0438\u043b\u0438 \u043d\u0435\u0442.","type":"boolean","required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"categories":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"id":{"description":"ID \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b. ","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"author":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u0430\u0432\u0442\u043e\u0440\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0430\u0432\u0442\u043e\u0440\u0430\u043c.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435\u043c menu_order.","type":"integer","required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u0435\u0439.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0437\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0435\u043c \u0438\u043c\u0435\u044e\u0449\u0438\u0445 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0441\u0442\u0430\u0442\u0443\u0441\u0430\u043c\u0438.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u043e \u043e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u044e \u043a \u0434\u0440\u0443\u0433\u0438\u043c \u0437\u0430\u043f\u0438\u0441\u044f\u043c.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u041f\u0435\u0440\u0435\u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0438\u0442\u044c \u0434\u043b\u0438\u043d\u0443 \u043e\u0442\u0440\u044b\u0432\u043a\u0430 \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e.","type":"integer","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0435\u0441\u043b\u0438 \u043e\u043d\u0430 \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u043e \u043e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u044e \u043a \u0434\u0440\u0443\u0433\u0438\u043c \u0437\u0430\u043f\u0438\u0441\u044f\u043c.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443. ","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u041f\u043e\u0440\u044f\u0434\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u043e \u043e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u044e \u043a \u0434\u0440\u0443\u0433\u0438\u043c \u0437\u0430\u043f\u0438\u0441\u044f\u043c.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"id":{"description":"ID \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b. ","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"author":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 \u0430\u0432\u0442\u043e\u0440\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0430\u0432\u0442\u043e\u0440\u0430\u043c.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u0435\u0439.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0437\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0435\u043c \u0438\u043c\u0435\u044e\u0449\u0438\u0445 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0441\u0442\u0430\u0442\u0443\u0441\u0430\u043c\u0438.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u0439 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u0442\u0438\u043f\u0430 \u043c\u0435\u0434\u0438\u0430.","type":"string","enum":["image","video","text","application","audio"],"required":false},"mime_type":{"default":null,"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u0439 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0433\u043e MIME \u0442\u0438\u043f\u0430.","type":"string","required":false}}},{"methods":["POST"],"args":{"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"alt_text":{"description":"\u0410\u043b\u044c\u0442\u0435\u0440\u043d\u0430\u0442\u0438\u0432\u043d\u044b\u0439 \u0442\u0435\u043a\u0441\u0442 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u043a\u043e\u0433\u0434\u0430 \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u0435 \u043d\u0435 \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u0442\u0441\u044f.","type":"string","required":false},"caption":{"description":"\u041f\u043e\u0434\u043f\u0438\u0441\u044c \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"object","properties":{"raw":{"description":"\u041f\u043e\u0434\u043f\u0438\u0441\u044c \u0434\u043b\u044f \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f, \u043a\u0430\u043a \u043e\u043d\u0430 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043f\u043e\u0434\u043f\u0438\u0441\u044c \u0434\u043b\u044f \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u0430\u044f \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"object","properties":{"raw":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID \u0434\u043b\u044f \u0430\u0441\u0441\u043e\u0446\u0438\u0438\u0440\u043e\u0432\u0430\u043d\u044b\u0445 \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0434\u043b\u044f \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"featured_media":{"description":"ID \u0438\u0437\u0431\u0440\u0430\u043d\u043d\u043e\u0433\u043e \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"comment_status":{"description":"\u041e\u0442\u043a\u0440\u044b\u0442\u044b \u043b\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u041f\u0440\u0438\u043d\u0438\u043c\u0430\u0435\u0442 \u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"alt_text":{"description":"\u0410\u043b\u044c\u0442\u0435\u0440\u043d\u0430\u0442\u0438\u0432\u043d\u044b\u0439 \u0442\u0435\u043a\u0441\u0442 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u043a\u043e\u0433\u0434\u0430 \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u0435 \u043d\u0435 \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u0442\u0441\u044f.","type":"string","required":false},"caption":{"description":"\u041f\u043e\u0434\u043f\u0438\u0441\u044c \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"object","properties":{"raw":{"description":"\u041f\u043e\u0434\u043f\u0438\u0441\u044c \u0434\u043b\u044f \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f, \u043a\u0430\u043a \u043e\u043d\u0430 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043f\u043e\u0434\u043f\u0438\u0441\u044c \u0434\u043b\u044f \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u0430\u044f \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"object","properties":{"raw":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID \u0434\u043b\u044f \u0430\u0441\u0441\u043e\u0446\u0438\u0438\u0440\u043e\u0432\u0430\u043d\u044b\u0445 \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0434\u043b\u044f \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0432\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL \u043e\u0442\u0440\u0435\u0434\u0430\u043a\u0442\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0433\u043e \u0444\u0430\u0439\u043b\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f","type":"string","format":"uri","required":true},"modifiers":{"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0440\u0435\u0434\u0430\u043a\u0442\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"array","minItems":1,"items":{"description":"\u0420\u0435\u0434\u0430\u043a\u0442\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u0435 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"object","required":["type","args"],"oneOf":[{"title":"\u0412\u0440\u0430\u0449\u0435\u043d\u0438\u0435","properties":{"type":{"description":"\u0422\u0438\u043f \u0432\u0440\u0430\u0449\u0435\u043d\u0438\u044f.","type":"string","enum":["rotate"]},"args":{"description":"\u0410\u0440\u0433\u0443\u043c\u0435\u043d\u0442\u044b \u0432\u0440\u0430\u0449\u0435\u043d\u0438\u044f.","type":"object","required":["angle"],"properties":{"angle":{"description":"\u0423\u0433\u043e\u043b \u0434\u043b\u044f \u043f\u043e\u0432\u043e\u0440\u043e\u0442\u0430 \u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u0439 \u0441\u0442\u0440\u0435\u043b\u043a\u0435.","type":"number"}}}}},{"title":"\u041e\u0431\u0440\u0435\u0437\u0430\u0442\u044c","properties":{"type":{"description":"\u0422\u0438\u043f \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f.","type":"string","enum":["crop"]},"args":{"description":"\u0410\u0440\u0433\u0443\u043c\u0435\u043d\u0442\u044b \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"\u0413\u043e\u0440\u0438\u0437\u043e\u043d\u0442\u0430\u043b\u044c\u043d\u043e\u0435 \u043f\u043e\u043b\u043e\u0436\u0435\u043d\u0438\u0435 \u0441\u043b\u0435\u0432\u0430 \u0434\u043b\u044f \u043d\u0430\u0447\u0430\u043b\u0430 \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f \u0432 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0448\u0438\u0440\u0438\u043d\u044b \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"number"},"top":{"description":"\u0412\u0435\u0440\u0442\u0438\u043a\u0430\u043b\u044c\u043d\u043e\u0435 \u043f\u043e\u043b\u043e\u0436\u0435\u043d\u0438\u0435 \u0441\u0432\u0435\u0440\u0445\u0443 \u0434\u043b\u044f \u043d\u0430\u0447\u0430\u043b\u0430 \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f \u0432 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0432\u044b\u0441\u043e\u0442\u044b \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"number"},"width":{"description":"\u0428\u0438\u0440\u0438\u043d\u0430 \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f \u0432 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0448\u0438\u0440\u0438\u043d\u044b \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"number"},"height":{"description":"\u0412\u044b\u0441\u043e\u0442\u0430 \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f \u0432 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0432\u044b\u0441\u043e\u0442\u044b \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f.","type":"number"}}}}}]},"required":false},"rotation":{"description":"\u0412\u0435\u043b\u0438\u0447\u0438\u043d\u0430 \u043f\u043e\u0432\u043e\u0440\u043e\u0442\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u0439 \u0441\u0442\u0440\u0435\u043b\u043a\u0435 \u0432 \u0433\u0440\u0430\u0434\u0443\u0441\u0430\u0445. \u0423\u0421\u0422\u0410\u0420\u0415\u041b\u041e: \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u043c\u043e\u0434\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b (`modifiers`).","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"\u0412 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0440\u0430\u0437\u043c\u0435\u0440\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f, \u043f\u043e\u0437\u0438\u0446\u0438\u044f \u043f\u043e \u043e\u0441\u0438 X \u0434\u043b\u044f \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f. \u0423\u0421\u0422\u0410\u0420\u0415\u041b\u041e: \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u043c\u043e\u0434\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b (`modifiers`).","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"\u0412 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0440\u0430\u0437\u043c\u0435\u0440\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f, \u043f\u043e\u0437\u0438\u0446\u0438\u044f \u043f\u043e \u043e\u0441\u0438 X \u0434\u043b\u044f \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f. \u0423\u0421\u0422\u0410\u0420\u0415\u041b\u041e: \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u043c\u043e\u0434\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b (`modifiers`).","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"\u0412 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0440\u0430\u0437\u043c\u0435\u0440\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f, \u0448\u0438\u0440\u0438\u043d\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0434\u043b\u044f \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f. \u0423\u0421\u0422\u0410\u0420\u0415\u041b\u041e: \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u043c\u043e\u0434\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b (`modifiers`).","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"\u0412 \u043f\u0440\u043e\u0446\u0435\u043d\u0442\u0430\u0445 \u043e\u0442 \u0440\u0430\u0437\u043c\u0435\u0440\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f, \u0432\u044b\u0441\u043e\u0442\u0430 \u0438\u0437\u043e\u0431\u0440\u0430\u0436\u0435\u043d\u0438\u044f \u0434\u043b\u044f \u043a\u0430\u0434\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f. \u0423\u0421\u0422\u0410\u0420\u0415\u041b\u041e: \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0439\u0442\u0435 \u043c\u043e\u0434\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440\u044b (`modifiers`).","type":"number","minimum":0,"maximum":100,"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b. ","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0441\u0442\u0430\u0442\u0443\u0441\u0430\u043c\u0438.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u043e\u0441\u043d\u043e\u0432\u044b\u0432\u0430\u044f\u0441\u044c \u043d\u0430 \u043e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u044f\u0445 \u043c\u0435\u0436\u0434\u0443 \u043c\u043d\u043e\u0436\u0435\u0441\u0442\u0432\u0435\u043d\u043d\u044b\u043c\u0438 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f\u043c\u0438.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 menus.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u041f\u0440\u0438\u043d\u0430\u0434\u043b\u0435\u0436\u043d\u043e\u0441\u0442\u044c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u043a\u043e \u0432\u0441\u0435\u043c \u0438\u043b\u0438 \u043b\u044e\u0431\u043e\u043c\u0443 \u0438\u0437 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u0445 \u0442\u0435\u0440\u043c\u0438\u043d\u043e\u0432.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 menus.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0437\u043d\u0430\u0447\u0435\u043d\u0438\u0435\u043c menu_order.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":["string","object"],"properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"\u0421\u0435\u043c\u0435\u0439\u0441\u0442\u0432\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432, \u043f\u0435\u0440\u0432\u043e\u043d\u0430\u0447\u0430\u043b\u044c\u043d\u043e \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u043d\u044b\u0445, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 \"post_type\" \u0438\u043b\u0438 \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u0422\u0435\u043a\u0441\u0442 \u0434\u043b\u044f \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 title \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 link \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","required":false},"classes":{"description":"\u0418\u043c\u0435\u043d\u0430 \u043a\u043b\u0430\u0441\u0441\u043e\u0432 \u0434\u043b\u044f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0441\u0441\u044b\u043b\u043a\u0438 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","required":false},"menu_order":{"default":1,"description":"ID \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445 nav_menu_item, \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u0435\u043c \u043c\u0435\u043d\u044e \u044d\u0442\u043e\u0433\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430, \u0435\u0441\u043b\u0438 \u0442\u0430\u043a\u043e\u0432\u043e\u0439 \u0438\u043c\u0435\u0435\u0442\u0441\u044f, 0 \u0432 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435.","type":"integer","minimum":1,"required":false},"object":{"description":"\u0422\u0438\u043f \u043f\u0435\u0440\u0432\u043e\u043d\u0430\u0447\u0430\u043b\u044c\u043d\u043e \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 \"category\", \"post\" \u0438\u043b\u0438 \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"ID \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445 \u0438\u0441\u0445\u043e\u0434\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u044f\u0435\u0442 \u044d\u0442\u043e\u0442 \u043f\u0443\u043d\u043a\u0442 \u043c\u0435\u043d\u044e, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 ID \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0438\u043b\u0438 term_id \u0434\u043b\u044f \u0440\u0443\u0431\u0440\u0438\u043a.","type":"integer","minimum":0,"required":false},"target":{"description":"\u0426\u0435\u043b\u0435\u0432\u043e\u0439 \u0430\u0442\u0440\u0438\u0431\u0443\u0442 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 link \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL-\u0430\u0434\u0440\u0435\u0441, \u043d\u0430 \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u0443\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442 \u044d\u0442\u043e\u0442 \u043f\u0443\u043d\u043a\u0442 \u043c\u0435\u043d\u044e.","type":"string","format":"uri","required":false},"xfn":{"description":"\u041e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u0435 XFN, \u0432\u044b\u0440\u0430\u0436\u0435\u043d\u043d\u043e\u0435 \u0432 \u0441\u0441\u044b\u043b\u043a\u0435 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 nav_menu.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":["string","object"],"properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u0421\u0435\u043c\u0435\u0439\u0441\u0442\u0432\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432, \u043f\u0435\u0440\u0432\u043e\u043d\u0430\u0447\u0430\u043b\u044c\u043d\u043e \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u043d\u044b\u0445, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 \"post_type\" \u0438\u043b\u0438 \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u0422\u0435\u043a\u0441\u0442 \u0434\u043b\u044f \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 title \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 link \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","required":false},"classes":{"description":"\u0418\u043c\u0435\u043d\u0430 \u043a\u043b\u0430\u0441\u0441\u043e\u0432 \u0434\u043b\u044f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0441\u0441\u044b\u043b\u043a\u0438 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","required":false},"menu_order":{"description":"ID \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445 nav_menu_item, \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u0435\u043c \u043c\u0435\u043d\u044e \u044d\u0442\u043e\u0433\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430, \u0435\u0441\u043b\u0438 \u0442\u0430\u043a\u043e\u0432\u043e\u0439 \u0438\u043c\u0435\u0435\u0442\u0441\u044f, 0 \u0432 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435.","type":"integer","minimum":1,"required":false},"object":{"description":"\u0422\u0438\u043f \u043f\u0435\u0440\u0432\u043e\u043d\u0430\u0447\u0430\u043b\u044c\u043d\u043e \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 \"category\", \"post\" \u0438\u043b\u0438 \"attachment\".","type":"string","required":false},"object_id":{"description":"ID \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445 \u0438\u0441\u0445\u043e\u0434\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u044f\u0435\u0442 \u044d\u0442\u043e\u0442 \u043f\u0443\u043d\u043a\u0442 \u043c\u0435\u043d\u044e, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 ID \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0438\u043b\u0438 term_id \u0434\u043b\u044f \u0440\u0443\u0431\u0440\u0438\u043a.","type":"integer","minimum":0,"required":false},"target":{"description":"\u0426\u0435\u043b\u0435\u0432\u043e\u0439 \u0430\u0442\u0440\u0438\u0431\u0443\u0442 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 link \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL-\u0430\u0434\u0440\u0435\u0441, \u043d\u0430 \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u0443\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442 \u044d\u0442\u043e\u0442 \u043f\u0443\u043d\u043a\u0442 \u043c\u0435\u043d\u044e.","type":"string","format":"uri","required":false},"xfn":{"description":"\u041e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u0435 XFN, \u0432\u044b\u0440\u0430\u0436\u0435\u043d\u043d\u043e\u0435 \u0432 \u0441\u0441\u044b\u043b\u043a\u0435 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 nav_menu.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"integer","minimum":0,"required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":["string","object"],"properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u0421\u0435\u043c\u0435\u0439\u0441\u0442\u0432\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432, \u043f\u0435\u0440\u0432\u043e\u043d\u0430\u0447\u0430\u043b\u044c\u043d\u043e \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u043d\u044b\u0445, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 \"post_type\" \u0438\u043b\u0438 \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0434\u043b\u044f \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"\u0422\u0435\u043a\u0441\u0442 \u0434\u043b\u044f \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 title \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 link \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","required":false},"classes":{"description":"\u0418\u043c\u0435\u043d\u0430 \u043a\u043b\u0430\u0441\u0441\u043e\u0432 \u0434\u043b\u044f \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0441\u0441\u044b\u043b\u043a\u0438 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","required":false},"menu_order":{"description":"ID \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445 nav_menu_item, \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u0435\u043c \u043c\u0435\u043d\u044e \u044d\u0442\u043e\u0433\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430, \u0435\u0441\u043b\u0438 \u0442\u0430\u043a\u043e\u0432\u043e\u0439 \u0438\u043c\u0435\u0435\u0442\u0441\u044f, 0 \u0432 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435.","type":"integer","minimum":1,"required":false},"object":{"description":"\u0422\u0438\u043f \u043f\u0435\u0440\u0432\u043e\u043d\u0430\u0447\u0430\u043b\u044c\u043d\u043e \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 \"category\", \"post\" \u0438\u043b\u0438 \"attachment\".","type":"string","required":false},"object_id":{"description":"ID \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445 \u0438\u0441\u0445\u043e\u0434\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430, \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u044f\u0435\u0442 \u044d\u0442\u043e\u0442 \u043f\u0443\u043d\u043a\u0442 \u043c\u0435\u043d\u044e, \u043d\u0430\u043f\u0440\u0438\u043c\u0435\u0440 ID \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0438\u043b\u0438 term_id \u0434\u043b\u044f \u0440\u0443\u0431\u0440\u0438\u043a.","type":"integer","minimum":0,"required":false},"target":{"description":"\u0426\u0435\u043b\u0435\u0432\u043e\u0439 \u0430\u0442\u0440\u0438\u0431\u0443\u0442 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 link \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL-\u0430\u0434\u0440\u0435\u0441, \u043d\u0430 \u043a\u043e\u0442\u043e\u0440\u044b\u0439 \u0443\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442 \u044d\u0442\u043e\u0442 \u043f\u0443\u043d\u043a\u0442 \u043c\u0435\u043d\u044e.","type":"string","format":"uri","required":false},"xfn":{"description":"\u041e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u0435 XFN, \u0432\u044b\u0440\u0430\u0436\u0435\u043d\u043d\u043e\u0435 \u0432 \u0441\u0441\u044b\u043b\u043a\u0435 \u044d\u0442\u043e\u0433\u043e \u043f\u0443\u043d\u043a\u0442\u0430 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 nav_menu.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"id":{"description":"ID \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b. ","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0441\u0442\u0430\u0442\u0443\u0441\u0430\u043c\u0438.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u043e\u0441\u043d\u043e\u0432\u044b\u0432\u0430\u044f\u0441\u044c \u043d\u0430 \u043e\u0442\u043d\u043e\u0448\u0435\u043d\u0438\u044f\u0445 \u043c\u0435\u0436\u0434\u0443 \u043c\u043d\u043e\u0436\u0435\u0441\u0442\u0432\u0435\u043d\u043d\u044b\u043c\u0438 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f\u043c\u0438.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u041f\u0440\u0438\u043d\u0430\u0434\u043b\u0435\u0436\u043d\u043e\u0441\u0442\u044c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u043a\u043e \u0432\u0441\u0435\u043c \u0438\u043b\u0438 \u043b\u044e\u0431\u043e\u043c\u0443 \u0438\u0437 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u0445 \u0442\u0435\u0440\u043c\u0438\u043d\u043e\u0432.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0441 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u044b\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u043c \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"\u0421\u043f\u0438\u0441\u043e\u043a ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432","description":"\u0421\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u0441 \u043f\u0435\u0440\u0435\u0447\u0438\u0441\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID.","type":"array","items":{"type":"integer"}},{"title":"\u0417\u0430\u043f\u0440\u043e\u0441 ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438","description":"\u0412\u044b\u043f\u043e\u043b\u043d\u0438\u0442\u044c \u0440\u0430\u0441\u0448\u0438\u0440\u0435\u043d\u043d\u044b\u0439 \u0437\u0430\u043f\u0440\u043e\u0441 \u043f\u043e \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c.","type":"object","properties":{"terms":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u043e\u0432.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"wp_pattern_category":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u041f\u0435\u0440\u0435\u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0438\u0442\u044c \u0434\u043b\u0438\u043d\u0443 \u043e\u0442\u0440\u044b\u0432\u043a\u0430 \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e.","type":"integer","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0435\u0441\u043b\u0438 \u043e\u043d\u0430 \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"wp_pattern_category":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443. ","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u041e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0438\u0437 \u0437\u0430\u043f\u0438\u0441\u0438 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043e\u0442\u0440\u044b\u0432\u043e\u043a \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0430\u0442\u044c \u043b\u0438 \u043f\u0430\u0440\u043e\u043b\u0435\u043c \u043e\u0442\u0440\u044b\u0432\u043e\u043a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"wp_pattern_category":{"description":"\u042d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u0431\u044a\u0435\u043a\u0442\u0443 \u0432 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438 wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"id":{"description":"ID \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443. ","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"slug":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u044f\u0440\u043b\u044b\u043a \u0434\u043b\u044f \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"type":{"description":"\u0422\u0438\u043f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u043c.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-\u0437\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"status":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"id":{"description":"ID \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0434\u043e \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u043e\u0433\u043e ID \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"area":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u0438\u0435 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0451\u043d\u043d\u043e\u0439 \u043e\u0431\u043b\u0430\u0441\u0442\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"post_type":{"description":"\u0422\u0438\u043f \u0437\u0430\u043f\u0438\u0441\u0438, \u0434\u043b\u044f \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043d\u0443\u0436\u043d\u043e \u043f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u0448\u0430\u0431\u043b\u043e\u043d\u044b.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u044f\u0440\u043b\u044b\u043a \u0434\u043b\u044f \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"type":{"description":"\u0422\u0438\u043f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"content":{"default":"","description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u043c.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-\u0437\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"status":{"default":"publish","description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u042f\u0440\u043b\u044b\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u0434\u043b\u044f \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043d\u0443\u0436\u043d\u043e \u043f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u0437\u0430\u043f\u0430\u0441\u043d\u043e\u0439 \u0432\u0430\u0440\u0438\u0430\u043d\u0442","type":"string","required":true},"is_custom":{"description":"\u0423\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442, \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u043b\u0438 \u0448\u0430\u0431\u043b\u043e\u043d \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c\u0441\u043a\u0438\u043c \u0438\u043b\u0438 \u0447\u0430\u0441\u0442\u044c\u044e \u0438\u0435\u0440\u0430\u0440\u0445\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u0432","type":"boolean","required":false},"template_prefix":{"description":"\u041f\u0440\u0435\u0444\u0438\u043a\u0441 \u0434\u043b\u044f \u0441\u043e\u0437\u0434\u0430\u0432\u0430\u0435\u043c\u043e\u0433\u043e \u0448\u0430\u0431\u043b\u043e\u043d\u0430. \u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u0442\u0441\u044f \u0434\u043b\u044f \u0438\u0437\u0432\u043b\u0435\u0447\u0435\u043d\u0438\u044f \u0442\u0438\u043f\u0430 \u043e\u0441\u043d\u043e\u0432\u043d\u043e\u0433\u043e \u0448\u0430\u0431\u043b\u043e\u043d\u0430. \u041d\u0430\u043f\u0440\u0438\u043c\u0435\u0440, \u0432 \u0441\u043b\u0443\u0447\u0430\u0435 \u00ab\u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f-\u043a\u043d\u0438\u0433\u0438\u00bb \u044d\u0442\u043e \u0431\u0443\u0434\u0435\u0442 \u00ab\u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"slug":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u044f\u0440\u043b\u044b\u043a \u0434\u043b\u044f \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"type":{"description":"\u0422\u0438\u043f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u043c.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-\u0437\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"status":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443. ","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"slug":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u044f\u0440\u043b\u044b\u043a \u0434\u043b\u044f \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"type":{"description":"\u0422\u0438\u043f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u043c.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-\u0437\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"status":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"integer","required":false},"area":{"description":"\u0413\u0434\u0435 \u043f\u0440\u0435\u0434\u043f\u043e\u043b\u0430\u0433\u0430\u0435\u0442\u0441\u044f \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u044c \u0447\u0430\u0441\u0442\u044c \u0448\u0430\u0431\u043b\u043e\u043d\u0430 ( \u0448\u0430\u043f\u043a\u0430, \u043f\u043e\u0434\u0432\u0430\u043b \u0438 \u0442.\u0434.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"id":{"description":"ID \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0434\u043e \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u043e\u0433\u043e ID \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"area":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0435\u043d\u0438\u0435 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0451\u043d\u043d\u043e\u0439 \u043e\u0431\u043b\u0430\u0441\u0442\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"post_type":{"description":"\u0422\u0438\u043f \u0437\u0430\u043f\u0438\u0441\u0438, \u0434\u043b\u044f \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043d\u0443\u0436\u043d\u043e \u043f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u0448\u0430\u0431\u043b\u043e\u043d\u044b.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u044f\u0440\u043b\u044b\u043a \u0434\u043b\u044f \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"type":{"description":"\u0422\u0438\u043f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"content":{"default":"","description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u043c.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-\u0437\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"status":{"default":"publish","description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"integer","required":false},"area":{"description":"\u0413\u0434\u0435 \u043f\u0440\u0435\u0434\u043f\u043e\u043b\u0430\u0433\u0430\u0435\u0442\u0441\u044f \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u044c \u0447\u0430\u0441\u0442\u044c \u0448\u0430\u0431\u043b\u043e\u043d\u0430 ( \u0448\u0430\u043f\u043a\u0430, \u043f\u043e\u0434\u0432\u0430\u043b \u0438 \u0442.\u0434.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u042f\u0440\u043b\u044b\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u0434\u043b\u044f \u043a\u043e\u0442\u043e\u0440\u043e\u0433\u043e \u043d\u0443\u0436\u043d\u043e \u043f\u043e\u043b\u0443\u0447\u0438\u0442\u044c \u0437\u0430\u043f\u0430\u0441\u043d\u043e\u0439 \u0432\u0430\u0440\u0438\u0430\u043d\u0442","type":"string","required":true},"is_custom":{"description":"\u0423\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442, \u044f\u0432\u043b\u044f\u0435\u0442\u0441\u044f \u043b\u0438 \u0448\u0430\u0431\u043b\u043e\u043d \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c\u0441\u043a\u0438\u043c \u0438\u043b\u0438 \u0447\u0430\u0441\u0442\u044c\u044e \u0438\u0435\u0440\u0430\u0440\u0445\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u0432","type":"boolean","required":false},"template_prefix":{"description":"\u041f\u0440\u0435\u0444\u0438\u043a\u0441 \u0434\u043b\u044f \u0441\u043e\u0437\u0434\u0430\u0432\u0430\u0435\u043c\u043e\u0433\u043e \u0448\u0430\u0431\u043b\u043e\u043d\u0430. \u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u0442\u0441\u044f \u0434\u043b\u044f \u0438\u0437\u0432\u043b\u0435\u0447\u0435\u043d\u0438\u044f \u0442\u0438\u043f\u0430 \u043e\u0441\u043d\u043e\u0432\u043d\u043e\u0433\u043e \u0448\u0430\u0431\u043b\u043e\u043d\u0430. \u041d\u0430\u043f\u0440\u0438\u043c\u0435\u0440, \u0432 \u0441\u043b\u0443\u0447\u0430\u0435 \u00ab\u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f-\u043a\u043d\u0438\u0433\u0438\u00bb \u044d\u0442\u043e \u0431\u0443\u0434\u0435\u0442 \u00ab\u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"slug":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u044f\u0440\u043b\u044b\u043a \u0434\u043b\u044f \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"type":{"description":"\u0422\u0438\u043f \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit"]},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u043e\u043c.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":["object","string"],"properties":{"raw":{"description":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0448\u0430\u0431\u043b\u043e\u043d\u0430 \u0432 \u0442\u043e\u043c \u0432\u0438\u0434\u0435, \u0432 \u043a\u043e\u0442\u043e\u0440\u043e\u043c \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-\u0437\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a \u0434\u043b\u044f \u0448\u0430\u0431\u043b\u043e\u043d\u0430, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","required":false},"status":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID \u0430\u0432\u0442\u043e\u0440\u0430 \u0448\u0430\u0431\u043b\u043e\u043d\u0430.","type":"integer","required":false},"area":{"description":"\u0413\u0434\u0435 \u043f\u0440\u0435\u0434\u043f\u043e\u043b\u0430\u0433\u0430\u0435\u0442\u0441\u044f \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u044c \u0447\u0430\u0441\u0442\u044c \u0448\u0430\u0431\u043b\u043e\u043d\u0430 ( \u0448\u0430\u043f\u043a\u0430, \u043f\u043e\u0434\u0432\u0430\u043b \u0438 \u0442.\u0434.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0433\u043b\u043e\u0431\u0430\u043b\u044c\u043d\u044b\u0445 \u0441\u0442\u0438\u043b\u0435\u0439.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0433\u043b\u043e\u0431\u0430\u043b\u044c\u043d\u044b\u0445 \u0441\u0442\u0438\u043b\u0435\u0439.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0435\u043c\u044b","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Id  \u0448\u0430\u0431\u043b\u043e\u043d\u0430","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"\u0413\u043b\u043e\u0431\u0430\u043b\u044c\u043d\u044b\u0435 \u0441\u0442\u0438\u043b\u0438.","type":["object"],"required":false},"settings":{"description":"\u041e\u0431\u0449\u0438\u0435 \u043d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438.","type":["object"],"required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0432\u0430\u0440\u0438\u0430\u0446\u0438\u0438 \u0433\u043b\u043e\u0431\u0430\u043b\u044c\u043d\u044b\u0445 \u0441\u0442\u0438\u043b\u0435\u0439.","type":["object","string"],"properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0432\u0430\u0440\u0438\u0430\u0446\u0438\u0438 \u0433\u043b\u043e\u0431\u0430\u043b\u044c\u043d\u044b\u0445 \u0441\u0442\u0438\u043b\u0435\u0439, \u0432 \u0432\u0438\u0434\u0435 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u044e\u0449\u0435\u043c \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b. ","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0441\u0442\u0430\u0442\u0443\u0441\u0430\u043c\u0438.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0435\u0441\u043b\u0438 \u043e\u043d\u0430 \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443. ","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0444\u043e\u0440\u043c\u0430\u0442\u0430 \u0431\u043b\u043e\u043a\u043e\u0432 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0433\u043e \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0437\u0430\u043f\u0438\u0441\u044c\u044e.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u0417\u0430\u0449\u0438\u0449\u0435\u043d\u043e \u043b\u0438 \u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"id":{"description":"ID \u0440\u0435\u0434\u0430\u043a\u0446\u0438\u0438 \u0430\u0432\u0442\u043e\u0441\u043e\u0445\u0440\u0430\u043d\u0435\u043d\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0441\u0445\u0435\u043c\u044b theme.json, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0434\u043b\u044f \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u0442\u0438\u043f\u043e\u0433\u0440\u0430\u0444\u0438\u043a\u0438.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u041e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u0438\u0435 font-face \u0432 \u0444\u043e\u0440\u043c\u0430\u0442\u0435 theme.json, \u0437\u0430\u043a\u043e\u0434\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u043a\u0430\u043a \u0441\u0442\u0440\u043e\u043a\u0430.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"theme_json_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0441\u0445\u0435\u043c\u044b theme.json, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0434\u043b\u044f \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u0442\u0438\u043f\u043e\u0433\u0440\u0430\u0444\u0438\u043a\u0438.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u041e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u0438\u0435 font-face \u0432 \u0444\u043e\u0440\u043c\u0430\u0442\u0435 theme.json, \u0437\u0430\u043a\u043e\u0434\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u043a\u0430\u043a \u0441\u0442\u0440\u043e\u043a\u0430.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0433\u043e \u0441\u0435\u043c\u0435\u0439\u0441\u0442\u0432\u0430 \u0448\u0440\u0438\u0444\u0442\u043e\u0432 \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043d\u0430\u0447\u0435\u0440\u0442\u0430\u043d\u0438\u044f \u0448\u0440\u0438\u0444\u0442\u0430.","type":"integer","required":true},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0433\u043e \u0441\u0435\u043c\u0435\u0439\u0441\u0442\u0432\u0430 \u0448\u0440\u0438\u0444\u0442\u043e\u0432 \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043d\u0430\u0447\u0435\u0440\u0442\u0430\u043d\u0438\u044f \u0448\u0440\u0438\u0444\u0442\u0430.","type":"integer","required":true},"theme_json_version":{"description":"\u0412\u0435\u0440\u0441\u0438\u044f \u0441\u0445\u0435\u043c\u044b theme.json, \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u0430\u044f \u0434\u043b\u044f \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u0442\u0438\u043f\u043e\u0433\u0440\u0430\u0444\u0438\u043a\u0438.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"\u041e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u0438\u0435 font-face \u0432 \u0444\u043e\u0440\u043c\u0430\u0442\u0435 theme.json, \u0437\u0430\u043a\u043e\u0434\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u043a\u0430\u043a \u0441\u0442\u0440\u043e\u043a\u0430.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0433\u043e \u0441\u0435\u043c\u0435\u0439\u0441\u0442\u0432\u0430 \u0448\u0440\u0438\u0444\u0442\u043e\u0432 \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043d\u0430\u0447\u0435\u0440\u0442\u0430\u043d\u0438\u044f \u0448\u0440\u0438\u0444\u0442\u0430.","type":"integer","required":true},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0430\u0440\u043d\u0438\u0442\u0443\u0440\u044b \u0448\u0440\u0438\u0444\u0442\u0430.","type":"integer","required":true},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0433\u043e \u0441\u0435\u043c\u0435\u0439\u0441\u0442\u0432\u0430 \u0448\u0440\u0438\u0444\u0442\u043e\u0432 \u0434\u043b\u044f \u0434\u0430\u043d\u043d\u043e\u0433\u043e \u043d\u0430\u0447\u0435\u0440\u0442\u0430\u043d\u0438\u044f \u0448\u0440\u0438\u0444\u0442\u0430.","type":"integer","required":true},"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0433\u0430\u0440\u043d\u0438\u0442\u0443\u0440\u044b \u0448\u0440\u0438\u0444\u0442\u0430.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/buddypress":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b. ","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u0437\u0430\u043f\u0438\u0441\u044f\u043c\u0438 \u0438\u0437\u043c\u0435\u043d\u0451\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u041a\u0430\u043a \u0438\u043d\u0442\u0435\u0440\u043f\u0440\u0435\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u0432\u0432\u043e\u0434\u0438\u043c\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u043f\u043e\u0438\u0441\u043a\u0430.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u0435\u0439.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0437\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0435\u043c \u0438\u043c\u0435\u044e\u0449\u0438\u0445 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0439 ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u043a\u043e\u043d\u043a\u0440\u0435\u0442\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u043c\u0438 \u0443\u0441\u0442\u0430\u043d\u043e\u0432\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0441\u0442\u0430\u0442\u0443\u0441\u0430\u043c\u0438.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/buddypress"}]}},"\/wp\/v2\/buddypress\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0435\u0441\u043b\u0438 \u043e\u043d\u0430 \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438 (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u043e GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0435 \u0442\u0438\u043f\u0430.","type":"string","required":false},"status":{"description":"\u0418\u043c\u0435\u043d\u043e\u0432\u0430\u043d\u043d\u044b\u0439 \u0441\u0442\u0430\u0442\u0443\u0441 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u0449\u0438\u0442\u044b \u0441\u043e\u0434\u0435\u0440\u0436\u0430\u043d\u0438\u044f \u0438 \u043e\u0442\u0440\u044b\u0432\u043a\u0430.","type":"string","required":false},"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"title":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"object","properties":{"raw":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u0430\u043a \u043e\u043d\u043e \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u0424\u0430\u0439\u043b \u0442\u0435\u043c\u044b \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u043c\u044b\u0439 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0438\u043f\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0441\u0442\u0430\u0442\u0443\u0441\u0430.","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u044f\u043c\u0438 \u0430\u0441\u0441\u043e\u0446\u0438\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0442\u0438\u043f\u043e\u043c \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0430\u043a\u0441\u043e\u043d\u043e\u043c\u0438\u0438.","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043d\u0438 \u043e\u0434\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"boolean","default":false,"required":false},"parent":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u043c\u0443 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044e.","type":"integer","required":false},"post":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","default":null,"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u0431\u043e\u043b\u0435\u0435 \u0441\u043f\u0435\u0446\u0438\u0430\u043b\u044c\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438. ","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":true},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"parent":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"parent":{"description":"ID \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f.","type":"integer","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043d\u0438 \u043e\u0434\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"boolean","default":false,"required":false},"post":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","default":null,"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u0431\u043e\u043b\u0435\u0435 \u0441\u043f\u0435\u0446\u0438\u0430\u043b\u044c\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438. ","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":true},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043d\u0438 \u043e\u0434\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"boolean","default":false,"required":false},"post":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","default":null,"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u0431\u043e\u043b\u0435\u0435 \u0441\u043f\u0435\u0446\u0438\u0430\u043b\u044c\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438. ","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":true},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false},"locations":{"description":"\u041c\u0435\u0441\u0442\u0430, \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u0421\u043b\u0435\u0434\u0443\u0435\u0442 \u043b\u0438 \u0430\u0432\u0442\u043e\u043c\u0430\u0442\u0438\u0447\u0435\u0441\u043a\u0438 \u0434\u043e\u0431\u0430\u0432\u043b\u044f\u0442\u044c \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u044b \u0432\u0435\u0440\u0445\u043d\u0435\u0433\u043e \u0443\u0440\u043e\u0432\u043d\u044f \u0432 \u044d\u0442\u043e \u043c\u0435\u043d\u044e.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false},"locations":{"description":"\u041c\u0435\u0441\u0442\u0430, \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043c\u0435\u043d\u044e.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u0421\u043b\u0435\u0434\u0443\u0435\u0442 \u043b\u0438 \u0430\u0432\u0442\u043e\u043c\u0430\u0442\u0438\u0447\u0435\u0441\u043a\u0438 \u0434\u043e\u0431\u0430\u0432\u043b\u044f\u0442\u044c \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u044b \u0432\u0435\u0440\u0445\u043d\u0435\u0433\u043e \u0443\u0440\u043e\u0432\u043d\u044f \u0432 \u044d\u0442\u043e \u043c\u0435\u043d\u044e.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430\u043c \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u0421\u043a\u0440\u044b\u0432\u0430\u0442\u044c \u043b\u0438 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043d\u0438 \u043e\u0434\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"boolean","default":false,"required":false},"post":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","default":null,"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u0431\u043e\u043b\u0435\u0435 \u0441\u043f\u0435\u0446\u0438\u0430\u043b\u044c\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438. ","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":true},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"description":{"description":"HTML \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"name":{"description":"HTML \u043d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"string","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430 \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0434\u043b\u044f \u0435\u0433\u043e \u0442\u0438\u043f\u0430.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u043e, \u0442\u0430\u043a \u043a\u0430\u043a \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u044b \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"default":"asc","description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u043c\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f\u043c\u0438 \u0441 \u043e\u0434\u043d\u0438\u043c \u0438\u043b\u0438 \u0431\u043e\u043b\u0435\u0435 \u0441\u043f\u0435\u0446\u0438\u0430\u043b\u044c\u043d\u044b\u043c\u0438 \u044f\u0440\u043b\u044b\u043a\u0430\u043c\u0438.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439 \u0443\u0434\u043e\u0432\u043b\u0435\u0442\u0432\u043e\u0440\u044f\u044e\u0449\u0438\u0445 \u043a\u0430\u043a \u043c\u0438\u043d\u0438\u043c\u0443\u043c \u043e\u0434\u043d\u043e\u0439 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u043e\u0439 \u0440\u043e\u043b\u0438. \u041c\u043e\u0436\u043d\u043e \u0443\u043a\u0430\u0437\u0430\u0442\u044c CSV \u0441\u043f\u0438\u0441\u043e\u043a \u0438\u043b\u0438 \u043e\u0434\u043d\u0443 \u0440\u043e\u043b\u044c.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439 \u0443\u0434\u043e\u0432\u043b\u0435\u0442\u0432\u043e\u0440\u044f\u044e\u0449\u0438\u0445 \u043a\u0430\u043a \u043c\u0438\u043d\u0438\u043c\u0443\u043c \u043e\u0434\u043d\u043e\u0439 \u0443\u043a\u0430\u0437\u0430\u043d\u043d\u043e\u0439 \u0440\u043e\u043b\u0438. \u041c\u043e\u0436\u043d\u043e \u0443\u043a\u0430\u0437\u0430\u0442\u044c CSV \u0441\u043f\u0438\u0441\u043e\u043a \u0438\u043b\u0438 \u043e\u0434\u043d\u0443 \u0440\u043e\u043b\u044c.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f\u043c\u0438-\u0430\u0432\u0442\u043e\u0440\u0430\u043c\u0438.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u044c\u0442\u0435 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f\u043c\u0438, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u0438\u043c\u0435\u044e\u0442 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u0435 \u0437\u0430\u043f\u0438\u0441\u0438.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","buddypress":"buddypress"}},"required":false},"search_columns":{"default":[],"description":"\u041c\u0430\u0441\u0441\u0438\u0432 \u0438\u043c\u0435\u043d \u0441\u0442\u043e\u043b\u0431\u0446\u043e\u0432 \u0434\u043b\u044f \u043f\u043e\u0438\u0441\u043a\u0430.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"\u0418\u043c\u044f \u0432\u0445\u043e\u0434\u0430 \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":true},"name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"first_name":{"description":"\u0418\u043c\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"last_name":{"description":"\u0424\u0430\u043c\u0438\u043b\u0438\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"email":{"description":"\u0410\u0434\u0440\u0435\u0441 email \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","format":"email","required":true},"url":{"description":"URL \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","format":"uri","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"locale":{"description":"\u041b\u043e\u043a\u0430\u043b\u044c \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","enum":["","en_US","ru_RU"],"required":false},"nickname":{"description":"\u041d\u0438\u043a \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"roles":{"description":"\u0420\u043e\u043b\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044e.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f (\u043d\u0438\u043a\u043e\u0433\u0434\u0430 \u043d\u0435 \u043f\u043e\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442\u0441\u044f).","type":"string","required":true},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u0414\u0430\u0442\u0430 \u0438 \u0432\u0440\u0435\u043c\u044f \u043e\u0431\u043d\u043e\u0432\u043b\u0435\u043d\u0438\u044f \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":false},"username":{"description":"\u0418\u043c\u044f \u0432\u0445\u043e\u0434\u0430 \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"first_name":{"description":"\u0418\u043c\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"last_name":{"description":"\u0424\u0430\u043c\u0438\u043b\u0438\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"email":{"description":"\u0410\u0434\u0440\u0435\u0441 email \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","format":"email","required":false},"url":{"description":"URL \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","format":"uri","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"locale":{"description":"\u041b\u043e\u043a\u0430\u043b\u044c \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","enum":["","en_US","ru_RU"],"required":false},"nickname":{"description":"\u041d\u0438\u043a \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"roles":{"description":"\u0420\u043e\u043b\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044e.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f (\u043d\u0438\u043a\u043e\u0433\u0434\u0430 \u043d\u0435 \u043f\u043e\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442\u0441\u044f).","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u0414\u0430\u0442\u0430 \u0438 \u0432\u0440\u0435\u043c\u044f \u043e\u0431\u043d\u043e\u0432\u043b\u0435\u043d\u0438\u044f \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u044b\u043c, \u0442\u0430\u043a \u043a\u0430\u043a \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439 \u043d\u0435\u043b\u044c\u0437\u044f \u043f\u0435\u0440\u0435\u043c\u0435\u0441\u0442\u0438\u0442\u044c \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443.","required":false},"reassign":{"type":"integer","description":"\u041f\u0435\u0440\u0435\u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0443\u0434\u0430\u043b\u0435\u043d\u043d\u044b\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f \u0438 \u0441\u0441\u044b\u043b\u043a\u0438 \u043d\u0430 \u044d\u0442\u043e\u0442 ID \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"\u0418\u043c\u044f \u0432\u0445\u043e\u0434\u0430 \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"first_name":{"description":"\u0418\u043c\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"last_name":{"description":"\u0424\u0430\u043c\u0438\u043b\u0438\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"email":{"description":"\u0410\u0434\u0440\u0435\u0441 email \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","format":"email","required":false},"url":{"description":"URL \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","format":"uri","required":false},"description":{"description":"\u041e\u043f\u0438\u0441\u0430\u043d\u0438\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"locale":{"description":"\u041b\u043e\u043a\u0430\u043b\u044c \u0434\u043b\u044f \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","enum":["","en_US","ru_RU"],"required":false},"nickname":{"description":"\u041d\u0438\u043a \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"slug":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","type":"string","required":false},"roles":{"description":"\u0420\u043e\u043b\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044e.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f (\u043d\u0438\u043a\u043e\u0433\u0434\u0430 \u043d\u0435 \u043f\u043e\u043a\u0430\u0437\u044b\u0432\u0430\u0435\u0442\u0441\u044f).","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u0414\u0430\u0442\u0430 \u0438 \u0432\u0440\u0435\u043c\u044f \u043e\u0431\u043d\u043e\u0432\u043b\u0435\u043d\u0438\u044f \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"\u0414\u043e\u043b\u0436\u043d\u043e \u0431\u044b\u0442\u044c \u0438\u0441\u0442\u0438\u043d\u043d\u044b\u043c, \u0442\u0430\u043a \u043a\u0430\u043a \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u0435\u0439 \u043d\u0435\u043b\u044c\u0437\u044f \u043f\u0435\u0440\u0435\u043c\u0435\u0441\u0442\u0438\u0442\u044c \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443.","required":false},"reassign":{"type":"integer","description":"\u041f\u0435\u0440\u0435\u043d\u0430\u0437\u043d\u0430\u0447\u0438\u0442\u044c \u0443\u0434\u0430\u043b\u0435\u043d\u043d\u044b\u0435 \u0437\u0430\u043f\u0438\u0441\u0438 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f \u0438 \u0441\u0441\u044b\u043b\u043a\u0438 \u043d\u0430 \u044d\u0442\u043e\u0442 ID \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f.","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"UUID \u043f\u0440\u0435\u0434\u043e\u0441\u0442\u0430\u0432\u043b\u044f\u0435\u043c\u044b\u0439 \u043f\u0440\u0438\u043b\u043e\u0436\u0435\u043d\u0438\u0435\u043c \u0434\u043b\u044f \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438. \u0420\u0435\u043a\u043e\u043c\u0435\u043d\u0434\u0443\u0435\u0442\u0441\u044f \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u044c UUID v5 \u0441 \u043f\u0440\u043e\u0441\u0442\u0440\u0430\u043d\u0441\u0442\u0432\u043e\u043c \u0438\u043c\u0435\u043d URL \u0438\u043b\u0438 DNS.","type":"string","format":"uuid","required":false},"name":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043f\u0430\u0440\u043e\u043b\u044f \u043f\u0440\u0438\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"UUID \u043f\u0440\u0435\u0434\u043e\u0441\u0442\u0430\u0432\u043b\u044f\u0435\u043c\u044b\u0439 \u043f\u0440\u0438\u043b\u043e\u0436\u0435\u043d\u0438\u0435\u043c \u0434\u043b\u044f \u0443\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0446\u0438\u0438. \u0420\u0435\u043a\u043e\u043c\u0435\u043d\u0434\u0443\u0435\u0442\u0441\u044f \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u044c UUID v5 \u0441 \u043f\u0440\u043e\u0441\u0442\u0440\u0430\u043d\u0441\u0442\u0432\u043e\u043c \u0438\u043c\u0435\u043d URL \u0438\u043b\u0438 DNS.","type":"string","format":"uuid","required":false},"name":{"description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u043f\u0430\u0440\u043e\u043b\u044f \u043f\u0440\u0438\u043b\u043e\u0436\u0435\u043d\u0438\u044f.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"after":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u043f\u043e\u0441\u043b\u0435 \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"author":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f\u043c\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u043c\u0443 ID \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f. \u0422\u0440\u0435\u0431\u0443\u0435\u0442 \u0430\u0432\u0442\u043e\u0440\u0438\u0437\u0430\u0446\u0438\u0438.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u0435 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u043c\u0443 ID \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f. \u0422\u0440\u0435\u0431\u0443\u0435\u0442 \u0430\u0432\u0442\u043e\u0440\u0438\u0437\u0430\u0446\u0438\u0438.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u0438\u043c\u0435\u044e\u0449\u0435\u0439 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0451\u043d\u043d\u044b\u0439 email \u0430\u0432\u0442\u043e\u0440\u0430. \u0422\u0440\u0435\u0431\u0443\u0435\u0442 \u0430\u0432\u0442\u043e\u0440\u0438\u0437\u0430\u0446\u0438\u0438.","format":"email","type":"string","required":false},"before":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u043e\u0442\u0432\u0435\u0442 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f\u043c\u0438 \u043e\u043f\u0443\u0431\u043b\u0438\u043a\u043e\u0432\u0430\u043d\u043d\u044b\u043c\u0438 \u0434\u043e \u0437\u0430\u0434\u0430\u043d\u043d\u043e\u0439 ISO8601 \u0441\u043e\u0432\u043c\u0435\u0441\u0442\u0438\u043c\u043e\u0439 \u0434\u0430\u0442\u044b.","type":"string","format":"date-time","required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c\u0438 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u0438\u043c\u0438 ID.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u0438\u0435 ID.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f\u043c\u0438 \u0441 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c\u0438 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c\u0438 ID \u0437\u0430\u043f\u0438\u0441\u0435\u0439.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0441\u0442\u0430\u0442\u0443\u0441\u043e\u043c. \u0422\u0440\u0435\u0431\u0443\u0435\u0442 \u0430\u0432\u0442\u043e\u0440\u0438\u0437\u0430\u0446\u0438\u0438. ","type":"string","required":false},"type":{"default":"comment","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f\u043c\u0438 \u0441 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u043c \u0442\u0438\u043f\u043e\u043c. \u0422\u0440\u0435\u0431\u0443\u0435\u0442 \u0430\u0432\u0442\u043e\u0440\u0438\u0437\u0430\u0446\u0438\u0438.","type":"string","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438, \u0435\u0441\u043b\u0438 \u043e\u043d\u0430 \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"ID \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0435\u0441\u043b\u0438 \u0430\u0432\u0442\u043e\u0440 - \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c.","type":"integer","required":false},"author_email":{"description":"\u0410\u0434\u0440\u0435\u0441 email \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","format":"email","required":false},"author_ip":{"description":"IP \u0430\u0434\u0440\u0435\u0441 \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","format":"ip","required":false},"author_name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","required":false},"author_url":{"description":"URL \u0434\u043b\u044f \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u0417\u043d\u0430\u0447\u0435\u043d\u0438\u0435 User-Agent \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML-\u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u0412\u0440\u0435\u043c\u044f \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f, \u043f\u043e GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"integer","required":false},"post":{"default":0,"description":"ID \u0430\u0441\u0441\u043e\u0446\u0438\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"status":{"description":"\u0421\u043e\u0441\u0442\u043e\u044f\u043d\u0438\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"integer","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f (\u0435\u0441\u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"integer","required":false},"author":{"description":"ID \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f, \u0435\u0441\u043b\u0438 \u0430\u0432\u0442\u043e\u0440 - \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c.","type":"integer","required":false},"author_email":{"description":"\u0410\u0434\u0440\u0435\u0441 email \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","format":"email","required":false},"author_ip":{"description":"IP \u0430\u0434\u0440\u0435\u0441 \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","format":"ip","required":false},"author_name":{"description":"\u041e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0435\u043c\u043e\u0435 \u0438\u043c\u044f \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","required":false},"author_url":{"description":"URL \u0434\u043b\u044f \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u0417\u043d\u0430\u0447\u0435\u043d\u0438\u0435 User-Agent \u0430\u0432\u0442\u043e\u0440\u0430 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","required":false},"content":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"object","properties":{"raw":{"description":"\u0421\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f, \u043a\u0430\u043a \u043e\u043d \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0432 \u0431\u0430\u0437\u0435 \u0434\u0430\u043d\u043d\u044b\u0445.","type":"string","context":["edit"]},"rendered":{"description":"HTML-\u0441\u043e\u0434\u0435\u0440\u0436\u0438\u043c\u043e\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f, \u043f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u0414\u0430\u0442\u0430 \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f (\u043f\u043e \u0447\u0430\u0441\u043e\u0432\u043e\u043c\u0443 \u043f\u043e\u044f\u0441\u0443 \u0441\u0430\u0439\u0442\u0430).","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u0412\u0440\u0435\u043c\u044f \u043f\u0443\u0431\u043b\u0438\u043a\u0430\u0446\u0438\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f, \u043f\u043e GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"ID \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044f \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"integer","required":false},"post":{"description":"ID \u0430\u0441\u0441\u043e\u0446\u0438\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0433\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false},"status":{"description":"\u0421\u043e\u0441\u0442\u043e\u044f\u043d\u0438\u0435 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"string","required":false},"meta":{"description":"\u041c\u0435\u0442\u0430 \u043f\u043e\u043b\u044f.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u0418\u0433\u043d\u043e\u0440\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0449\u0435\u043d\u0438\u0435 \u0432 \u043a\u043e\u0440\u0437\u0438\u043d\u0443 \u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u044f\u0442\u044c.","required":false},"password":{"description":"\u041f\u0430\u0440\u043e\u043b\u044c \u0434\u043b\u044f \u0440\u043e\u0434\u0438\u0442\u0435\u043b\u044c\u0441\u043a\u043e\u0439 \u0437\u0430\u043f\u0438\u0441\u0438 \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u044f (\u0435\u0441\u043b\u0438 \u0437\u0430\u043f\u0438\u0441\u044c \u0437\u0430\u0449\u0438\u0449\u0435\u043d\u0430 \u043f\u0430\u0440\u043e\u043b\u0435\u043c).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"type":{"default":"post","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u0442\u0438\u043f\u0430 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u044d\u043b\u0435\u043c\u0435\u043d\u0442\u0430\u043c\u0438 \u043e\u0434\u043d\u043e\u0433\u043e \u0438\u043b\u0438 \u043d\u0435\u0441\u043a\u043e\u043b\u044c\u043a\u0438\u0445 \u043f\u043e\u0434\u0442\u0438\u043f\u043e\u0432 \u043e\u0431\u044a\u0435\u043a\u0442\u0430.","type":"array","items":{"enum":["post","page","buddypress","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"\u0423\u0431\u0435\u0434\u0438\u0442\u044c\u0441\u044f \u0447\u0442\u043e \u0432\u044b\u0431\u043e\u0440\u043a\u0430 \u0438\u0441\u043a\u043b\u044e\u0447\u0430\u0435\u0442 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0435 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0434\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u044b\u0445 ID.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u043e\u0435, \u0437\u0430\u0440\u0435\u0433\u0438\u0441\u0442\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u0434\u043b\u044f \u0431\u043b\u043e\u043a\u0430 \u0438\u043c\u044f.","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"\u0410\u0442\u0440\u0438\u0431\u0443\u0442\u044b \u0434\u043b\u044f \u0431\u043b\u043e\u043a\u0430.","type":"object","default":[],"required":false},"post_id":{"description":"ID \u043a\u043e\u043d\u0442\u0435\u043a\u0441\u0442\u0430 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u041f\u0440\u043e\u0441\u0442\u0440\u0430\u043d\u0441\u0442\u0432\u043e \u0438\u043c\u0435\u043d \u0431\u043b\u043e\u043a\u0430.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u041f\u0440\u043e\u0441\u0442\u0440\u0430\u043d\u0441\u0442\u0432\u043e \u0438\u043c\u0435\u043d \u0431\u043b\u043e\u043a\u0430.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u0418\u043c\u044f \u0431\u043b\u043e\u043a\u0430.","type":"string","required":false},"namespace":{"description":"\u041f\u0440\u043e\u0441\u0442\u0440\u0430\u043d\u0441\u0442\u0432\u043e \u0438\u043c\u0435\u043d \u0431\u043b\u043e\u043a\u0430.","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"\u0417\u0430\u0433\u043e\u043b\u043e\u0432\u043e\u043a","description":"\u041d\u0430\u0437\u0432\u0430\u043d\u0438\u0435 \u0441\u0430\u0439\u0442\u0430.","type":"string","required":false},"description":{"title":"\u041a\u0440\u0430\u0442\u043a\u043e\u0435 \u043e\u043f\u0438\u0441\u0430\u043d\u0438\u0435","description":"\u0421\u043b\u043e\u0433\u0430\u043d \u0441\u0430\u0439\u0442\u0430.","type":"string","required":false},"url":{"title":"","description":"\u0410\u0434\u0440\u0435\u0441 \u0441\u0430\u0439\u0442\u0430 (URL)","type":"string","format":"uri","required":false},"email":{"title":"","description":"\u042d\u0442\u043e\u0442 \u0430\u0434\u0440\u0435\u0441 \u0438\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u0442\u0441\u044f \u0432 \u0446\u0435\u043b\u044f\u0445 \u0430\u0434\u043c\u0438\u043d\u0438\u0441\u0442\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f. \u041d\u0430\u043f\u0440\u0438\u043c\u0435\u0440, \u0434\u043b\u044f \u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u043e \u043d\u043e\u0432\u044b\u0445 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044f\u0445.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"\u0413\u043e\u0440\u043e\u0434 \u0432 \u0442\u043e\u0439 \u0436\u0435 \u0432\u0440\u0435\u043c\u0435\u043d\u043d\u043e\u0439 \u0437\u043e\u043d\u0435 \u0447\u0442\u043e \u0438 \u0443 \u0432\u0430\u0441.","type":"string","required":false},"date_format":{"title":"","description":"\u041e\u0431\u0449\u0438\u0439 \u0444\u043e\u0440\u043c\u0430\u0442 \u0434\u0430\u0442\u044b.","type":"string","required":false},"time_format":{"title":"","description":"\u041e\u0431\u0449\u0438\u0439 \u0444\u043e\u0440\u043c\u0430\u0442 \u0432\u0440\u0435\u043c\u0435\u043d\u0438.","type":"string","required":false},"start_of_week":{"title":"","description":"\u041f\u0435\u0440\u0432\u044b\u0439 \u0434\u0435\u043d\u044c \u043d\u0435\u0434\u0435\u043b\u0438.","type":"integer","required":false},"language":{"title":"","description":"\u041a\u043e\u0434 \u043b\u043e\u043a\u0430\u043b\u0438 WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"\u041f\u0440\u0435\u043e\u0431\u0440\u0430\u0437\u043e\u0432\u044b\u0432\u0430\u0442\u044c \u0441\u043c\u0430\u0439\u043b\u0438\u043a\u0438 \u043d\u0430\u043f\u043e\u0434\u043e\u0431\u0438\u0435 :-) \u0438 :-P \u0432 \u043a\u0430\u0440\u0442\u0438\u043d\u043a\u0438 \u043f\u0440\u0438 \u043f\u043e\u043a\u0430\u0437\u0435.","type":"boolean","required":false},"default_category":{"title":"","description":"\u0420\u0443\u0431\u0440\u0438\u043a\u0430 \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e.","type":"integer","required":false},"default_post_format":{"title":"","description":"\u0424\u043e\u0440\u043c\u0430\u0442 \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u043f\u043e \u0443\u043c\u043e\u043b\u0447\u0430\u043d\u0438\u044e.","type":"string","required":false},"posts_per_page":{"title":"\u041c\u0430\u043a\u0441\u0438\u043c\u0443\u043c \u0437\u0430\u043f\u0438\u0441\u0435\u0439 \u043d\u0430 \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0443","description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0443\u043c \u0441\u0442\u0440\u0430\u043d\u0438\u0446 \u0431\u043b\u043e\u0433\u0430 \u0434\u043b\u044f \u043f\u043e\u043a\u0430\u0437\u0430.","type":"integer","required":false},"show_on_front":{"title":"\u041f\u043e\u043a\u0430\u0437\u044b\u0432\u0430\u0442\u044c \u0432\u043e \u0432\u043d\u0435\u0448\u043d\u0435\u0439 \u0447\u0430\u0441\u0442\u0438","description":"\u0427\u0442\u043e \u043f\u043e\u043a\u0430\u0437\u0430\u0442\u044c \u043d\u0430 \u0433\u043b\u0430\u0432\u043d\u043e\u0439 \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0435","type":"string","required":false},"page_on_front":{"title":"\u0421\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u0432\u043d\u0435\u0448\u043d\u0435\u0439 \u0447\u0430\u0441\u0442\u0438","description":"ID \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u044b, \u043a\u043e\u0442\u043e\u0440\u0430\u044f \u0434\u043e\u043b\u0436\u043d\u0430 \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0442\u044c\u0441\u044f \u043d\u0430 \u0433\u043b\u0430\u0432\u043d\u043e\u0439 \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0435","type":"integer","required":false},"page_for_posts":{"title":"","description":"ID \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u044b, \u043d\u0430 \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u0434\u043e\u043b\u0436\u043d\u044b \u043e\u0442\u043e\u0431\u0440\u0430\u0436\u0430\u0442\u044c\u0441\u044f \u043f\u043e\u0441\u043b\u0435\u0434\u043d\u0438\u0435 \u0437\u0430\u043f\u0438\u0441\u0438","type":"integer","required":false},"default_ping_status":{"title":"","description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0438\u0442\u044c \u0441\u0441\u044b\u043b\u043a\u0438 \u043e\u043f\u043e\u0432\u0435\u0449\u0435\u043d\u0438\u044f \u0441 \u0434\u0440\u0443\u0433\u0438\u0445 \u0431\u043b\u043e\u0433\u043e\u0432 (\u0443\u0432\u0435\u0434\u043e\u043c\u043b\u0435\u043d\u0438\u044f \u0438 \u043e\u0431\u0440\u0430\u0442\u043d\u044b\u0435 \u0441\u0441\u044b\u043b\u043a\u0438) \u043d\u0430 \u043d\u043e\u0432\u044b\u0435 \u0441\u0442\u0430\u0442\u044c\u0438.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"\u0420\u0430\u0437\u0440\u0435\u0448\u0438\u0442\u044c \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u0434\u043b\u044f \u043d\u043e\u0432\u044b\u0445 \u0437\u0430\u043f\u0438\u0441\u0435\u0439","description":"\u0420\u0430\u0437\u0440\u0435\u0448\u0438\u0442\u044c \u043e\u0441\u0442\u0430\u0432\u043b\u044f\u0442\u044c \u043a\u043e\u043c\u043c\u0435\u043d\u0442\u0430\u0440\u0438\u0438 \u043a \u043d\u043e\u0432\u044b\u043c \u0437\u0430\u043f\u0438\u0441\u044f\u043c.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"\u041b\u043e\u0433\u043e\u0442\u0438\u043f","description":"\u041b\u043e\u0433\u043e\u0442\u0438\u043f \u0441\u0430\u0439\u0442\u0430","type":"integer","required":false},"site_icon":{"title":"\u0417\u043d\u0430\u0447\u043e\u043a","description":"\u0417\u043d\u0430\u0447\u043e\u043a \u0441\u0430\u0439\u0442\u0430.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442 \u0442\u0435\u043c\u0430\u043c\u0438 \u0441 \u043d\u0430\u0437\u043d\u0430\u0447\u0435\u043d\u043d\u044b\u043c \u0441\u0442\u0430\u0442\u0443\u0441\u043e\u043c.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"\u0422\u0430\u0431\u043b\u0438\u0446\u0430 \u0441\u0442\u0438\u043b\u0435\u0439 \u0442\u0435\u043c\u044b, \u043e\u0434\u043d\u043e\u0437\u043d\u0430\u0447\u043d\u043e \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0449\u0430\u044f \u0442\u0435\u043c\u0443.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","required":false},"status":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u043f\u043b\u0430\u0433\u0438\u043d\u0430\u043c\u0438 \u0441 \u0437\u0430\u0434\u0430\u043d\u043d\u044b\u043c \u0441\u0442\u0430\u0442\u0443\u0441\u043e\u043c.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"\u042f\u0440\u043b\u044b\u043a \u043f\u043b\u0430\u0433\u0438\u043d\u0430 \u0432 \u043a\u0430\u0442\u0430\u043b\u043e\u0433\u0435 WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0430\u043a\u0442\u0438\u0432\u0430\u0446\u0438\u0438 \u043f\u043b\u0430\u0433\u0438\u043d\u0430.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"\u0421\u0442\u0430\u0442\u0443\u0441 \u0430\u043a\u0442\u0438\u0432\u0430\u0446\u0438\u0438 \u043f\u043b\u0430\u0433\u0438\u043d\u0430.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0437\u0430\u0440\u0435\u0433\u0438\u0441\u0442\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0439 \u043e\u0431\u043b\u0430\u0441\u0442\u0438 \u0432\u0438\u0434\u0436\u0435\u0442\u043e\u0432","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"\u0412\u043b\u043e\u0436\u0435\u043d\u043d\u044b\u0435 \u0432\u0438\u0434\u0436\u0435\u0442\u044b.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0438\u043f\u0430 \u0432\u0438\u0434\u0436\u0435\u0442\u0430.","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0438\u043f\u0430 \u0432\u0438\u0434\u0436\u0435\u0442\u0430.","type":"string","required":true},"instance":{"description":"\u041d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438 \u0442\u0435\u043a\u0443\u0449\u0435\u0433\u043e \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430 \u0432\u0438\u0434\u0436\u0435\u0442\u0430.","type":"object","required":false},"form_data":{"description":"\u0421\u0435\u0440\u0438\u0430\u043b\u0438\u0437\u043e\u0432\u0430\u043d\u043d\u044b\u0435 \u0434\u0430\u043d\u043d\u044b\u0435 \u0444\u043e\u0440\u043c\u044b \u0432\u0438\u0434\u0436\u0435\u0442\u0430 \u0434\u043b\u044f \u043a\u043e\u0434\u0438\u0440\u043e\u0432\u043a\u0438 \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u0418\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0442\u0438\u043f\u0430 \u0432\u0438\u0434\u0436\u0435\u0442\u0430.","type":"string","required":true},"instance":{"description":"\u041d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438 \u0442\u0435\u043a\u0443\u0449\u0435\u0433\u043e \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430 \u0432\u0438\u0434\u0436\u0435\u0442\u0430.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"\u0411\u043e\u043a\u043e\u0432\u0430\u044f \u043f\u0430\u043d\u0435\u043b\u044c, \u0434\u043b\u044f \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u043d\u0443\u0436\u043d\u043e \u0432\u0435\u0440\u043d\u0443\u0442\u044c \u0432\u0438\u0434\u0436\u0435\u0442\u044b.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0432\u0438\u0434\u0436\u0435\u0442\u0430.","type":"string","required":false},"id_base":{"description":"\u0422\u0438\u043f \u0432\u0438\u0434\u0436\u0435\u0442\u0430. \u0421\u043e\u043e\u0442\u0432\u0435\u0442\u0441\u0442\u0432\u0443\u0435\u0442 ID \u0432 \u043a\u043e\u043d\u0435\u0447\u043d\u043e\u0439 \u0442\u043e\u0447\u043a\u0435 widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"\u0411\u043e\u043a\u043e\u0432\u0430\u044f \u043f\u0430\u043d\u0435\u043b\u044c, \u043a \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u043f\u0440\u0438\u043d\u0430\u0434\u043b\u0435\u0436\u0438\u0442 \u0432\u0438\u0434\u0436\u0435\u0442.","type":"string","required":true},"instance":{"description":"\u041d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438 \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430 \u0432\u0438\u0434\u0436\u0435\u0442\u0430 (\u0435\u0441\u043b\u0438 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442\u0441\u044f).","type":"object","properties":{"encoded":{"description":"Base64-\u043a\u043e\u0434\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u0438\u0435 \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430.","type":"string","context":["edit"]},"hash":{"description":"\u041a\u0440\u0438\u043f\u0442\u043e\u0433\u0440\u0430\u0444\u0438\u0447\u0435\u0441\u043a\u0438\u0439 \u0445\u044d\u0448 \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430.","type":"string","context":["edit"]},"raw":{"description":"\u041d\u0435\u0437\u0430\u0448\u0438\u0444\u0440\u043e\u0432\u0430\u043d\u043d\u044b\u0435 \u043d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438 \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430, \u0435\u0441\u043b\u0438 \u043e\u043d\u0438 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442\u0441\u044f.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u0414\u0430\u043d\u043d\u044b\u0435 \u0444\u043e\u0440\u043c\u044b \u0432 \u043a\u043e\u0434\u0438\u0440\u043e\u0432\u043a\u0435 URL \u0438\u0437 \u0444\u043e\u0440\u043c\u044b \u0430\u0434\u043c\u0438\u043d\u0438\u0441\u0442\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f \u0432\u0438\u0434\u0436\u0435\u0442\u0430. \u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u0442\u0441\u044f \u0434\u043b\u044f \u043e\u0431\u043d\u043e\u0432\u043b\u0435\u043d\u0438\u044f \u0432\u0438\u0434\u0436\u0435\u0442\u0430, \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0449\u0435\u0433\u043e \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u044b. \u0422\u043e\u043b\u044c\u043a\u043e \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u0423\u043d\u0438\u043a\u0430\u043b\u044c\u043d\u044b\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0434\u043b\u044f \u0432\u0438\u0434\u0436\u0435\u0442\u0430.","type":"string","required":false},"id_base":{"description":"\u0422\u0438\u043f \u0432\u0438\u0434\u0436\u0435\u0442\u0430. \u0421\u043e\u043e\u0442\u0432\u0435\u0442\u0441\u0442\u0432\u0443\u0435\u0442 ID \u0432 \u043a\u043e\u043d\u0435\u0447\u043d\u043e\u0439 \u0442\u043e\u0447\u043a\u0435 widget-types.","type":"string","required":false},"sidebar":{"description":"\u0411\u043e\u043a\u043e\u0432\u0430\u044f \u043f\u0430\u043d\u0435\u043b\u044c, \u043a \u043a\u043e\u0442\u043e\u0440\u043e\u0439 \u043f\u0440\u0438\u043d\u0430\u0434\u043b\u0435\u0436\u0438\u0442 \u0432\u0438\u0434\u0436\u0435\u0442.","type":"string","required":false},"instance":{"description":"\u041d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438 \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430 \u0432\u0438\u0434\u0436\u0435\u0442\u0430 (\u0435\u0441\u043b\u0438 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442\u0441\u044f).","type":"object","properties":{"encoded":{"description":"Base64-\u043a\u043e\u0434\u0438\u0440\u043e\u0432\u0430\u043d\u043d\u043e\u0435 \u043f\u0440\u0435\u0434\u0441\u0442\u0430\u0432\u043b\u0435\u043d\u0438\u0435 \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430.","type":"string","context":["edit"]},"hash":{"description":"\u041a\u0440\u0438\u043f\u0442\u043e\u0433\u0440\u0430\u0444\u0438\u0447\u0435\u0441\u043a\u0438\u0439 \u0445\u044d\u0448 \u043d\u0430\u0441\u0442\u0440\u043e\u0435\u043a \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430.","type":"string","context":["edit"]},"raw":{"description":"\u041d\u0435\u0437\u0430\u0448\u0438\u0444\u0440\u043e\u0432\u0430\u043d\u043d\u044b\u0435 \u043d\u0430\u0441\u0442\u0440\u043e\u0439\u043a\u0438 \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u0430, \u0435\u0441\u043b\u0438 \u043e\u043d\u0438 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0442\u0441\u044f.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u0414\u0430\u043d\u043d\u044b\u0435 \u0444\u043e\u0440\u043c\u044b \u0432 \u043a\u043e\u0434\u0438\u0440\u043e\u0432\u043a\u0435 URL \u0438\u0437 \u0444\u043e\u0440\u043c\u044b \u0430\u0434\u043c\u0438\u043d\u0438\u0441\u0442\u0440\u0438\u0440\u043e\u0432\u0430\u043d\u0438\u044f \u0432\u0438\u0434\u0436\u0435\u0442\u0430. \u0418\u0441\u043f\u043e\u043b\u044c\u0437\u0443\u0435\u0442\u0441\u044f \u0434\u043b\u044f \u043e\u0431\u043d\u043e\u0432\u043b\u0435\u043d\u0438\u044f \u0432\u0438\u0434\u0436\u0435\u0442\u0430, \u043d\u0435 \u043f\u043e\u0434\u0434\u0435\u0440\u0436\u0438\u0432\u0430\u044e\u0449\u0435\u0433\u043e \u044d\u043a\u0437\u0435\u043c\u043f\u043b\u044f\u0440\u044b. \u0422\u043e\u043b\u044c\u043a\u043e \u0434\u043b\u044f \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"\u0421\u043b\u0435\u0434\u0443\u0435\u0442 \u043b\u0438 \u043f\u0440\u0438\u043d\u0443\u0434\u0438\u0442\u0435\u043b\u044c\u043d\u043e \u0443\u0434\u0430\u043b\u0438\u0442\u044c \u0432\u0438\u0434\u0436\u0435\u0442 \u0438\u043b\u0438 \u043f\u0435\u0440\u0435\u043c\u0435\u0441\u0442\u0438\u0442\u044c \u0435\u0433\u043e \u043d\u0430 \u043d\u0435\u0430\u043a\u0442\u0438\u0432\u043d\u0443\u044e \u0431\u043e\u043a\u043e\u0432\u0443\u044e \u043f\u0430\u043d\u0435\u043b\u044c.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u044c\u0442\u0435 \u043d\u0430\u0431\u043e\u0440 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u043e\u0432 \u0431\u043b\u043e\u043a\u0430\u043c\u0438, \u0441\u043e\u043e\u0442\u0432\u0435\u0442\u0441\u0442\u0432\u0443\u044e\u0449\u0438\u043c\u0438 \u043f\u043e\u0438\u0441\u043a\u043e\u0432\u043e\u043c\u0443 \u0437\u0430\u043f\u0440\u043e\u0441\u0443.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441\u043e \u0441\u0442\u0440\u043e\u043a\u043e\u0439.","type":"string","minLength":1,"required":false},"category":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441 ID \u0440\u0443\u0431\u0440\u0438\u043a\u0438.","type":"integer","minimum":1,"required":false},"keyword":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u044b \u0434\u043e \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0449\u0438\u0445 \u0441 ID \u043a\u043b\u044e\u0447\u0435\u0432\u043e\u0433\u043e \u0441\u043b\u043e\u0432\u0430.","type":"integer","minimum":1,"required":false},"slug":{"description":"\u041e\u0433\u0440\u0430\u043d\u0438\u0447\u0438\u0442\u044c \u0432\u044b\u0431\u043e\u0440\u043a\u0443 \u0440\u0435\u0437\u0443\u043b\u044c\u0442\u0430\u0442\u0430\u043c\u0438, \u043a\u043e\u0442\u043e\u0440\u044b\u0435 \u0441\u043e\u0432\u043f\u0430\u0434\u0430\u044e\u0442 \u0441 \u043f\u0430\u0442\u0442\u0435\u0440\u043d\u043e\u043c (\u044f\u0440\u043b\u044b\u043a\u043e\u043c).","type":"array","required":false},"offset":{"description":"\u0421\u0434\u0432\u0438\u0433 \u0432\u044b\u0431\u043e\u0440\u043a\u0438 \u043d\u0430 \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u0435\u043d\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432.","type":"integer","required":false},"order":{"description":"\u0423\u043f\u043e\u0440\u044f\u0434\u043e\u0447\u0438\u0442\u044c \u0441\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u043a\u0443 \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0430 \u043f\u043e \u0432\u043e\u0437\u0440\u0430\u0441\u0442\u0430\u043d\u0438\u044e \u0438\u043b\u0438 \u0443\u0431\u044b\u0432\u0430\u043d\u0438\u044e.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u0421\u043e\u0440\u0442\u0438\u0440\u043e\u0432\u0430\u0442\u044c \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u044e \u043f\u043e \u0430\u0442\u0440\u0438\u0431\u0443\u0442\u0443 \u0437\u0430\u043f\u0438\u0441\u0438.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL \u0434\u043b\u044f \u043e\u0431\u0440\u0430\u0431\u043e\u0442\u043a\u0438.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"\u0411\u0443\u043a\u0432\u0435\u043d\u043d\u043e-\u0446\u0438\u0444\u0440\u043e\u0432\u043e\u0439 \u0438\u0434\u0435\u043d\u0442\u0438\u0444\u0438\u043a\u0430\u0442\u043e\u0440 \u0440\u0430\u0441\u043f\u043e\u043b\u043e\u0436\u0435\u043d\u0438\u044f \u043c\u0435\u043d\u044e.","type":"string","required":false},"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u0422\u0435\u043a\u0443\u0449\u0430\u044f \u0441\u0442\u0440\u0430\u043d\u0438\u0446\u0430 \u043a\u043e\u043b\u043b\u0435\u043a\u0446\u0438\u0438.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u041c\u0430\u043a\u0441\u0438\u043c\u0430\u043b\u044c\u043d\u043e\u0435 \u0447\u0438\u0441\u043b\u043e \u043e\u0431\u044a\u0435\u043a\u0442\u043e\u0432 \u0432\u043e\u0437\u0432\u0440\u0430\u0449\u0430\u0435\u043c\u043e\u0435 \u0432 \u0432\u044b\u0431\u043e\u0440\u043a\u0435.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u0420\u0430\u043c\u043a\u0438 \u0432 \u043a\u043e\u0442\u043e\u0440\u044b\u0445 \u0441\u0434\u0435\u043b\u0430\u043d \u0437\u0430\u043f\u0440\u043e\u0441, \u043e\u043f\u0440\u0435\u0434\u0435\u043b\u044f\u044e\u0442 \u043f\u043e\u043b\u044f \u0432 \u043e\u0442\u0432\u0435\u0442\u0435.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]}},"site_logo":0,"site_icon":96,"site_icon_url":"https:\/\/forum.bim2b.ru\/wp-content\/uploads\/2022\/11\/android-chrome-192x192-1.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/forum.bim2b.ru\/wp-json\/wp\/v2\/media\/96"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
